Responsivegridmacro | ||||||||||||||
UI Text Box | ||
Starting with In V-Ray 5 Update 26, VRayMtlVRayClipper, VRayFastSSS2, VRay2SidedMtl, VRayAlSurfaceMtl, VRayColor, VRayProxy and VRayClipper VRayDecal, and VRayProxy use QT for their GUI in 3ds Max versions 2018 2019 and later. This means they will follow 3ds Max’s logic for RMB actions on the spinners. RMB will reset the values to minimum and Ctrl+right-click will set the values to their default. |
