HideElements
cssselector#tocVertical, #tocHorizontal
This page introduces the Volumetric Grid Parameters located in the Modify tab.
width60%
After the VRayVolumeGrid is created, its parameters can be accessed on the Modify tab of the Command panel.
UI Expand
titleUI Path: ||Select V-Ray Volume Grid|| > Command panel > Modify tab
width5%
width35%
Rollouts
Div
stylepadding-left: 5px;padding-right: 5px;padding-bottom: 10px;
classdashboard
Textboxcard
PageToIncludeSystem Requirements
CardPageLinkFrame Info Rollout
Frame Info Rollout
Displays information on the loaded volume data.
Textboxcard
CardPageLinkGrid Rollout
Grid Rollout
Provides controls to render a volume without any loaded cache from the Input rollout.
Textboxcard
PageToIncludeInstallation
CardPageLinkInput Rollout
Input Rollout
Provides controls for multiple frame input, timing of frames, and blending/smoothing of frames.
Textboxcard
PageToIncludeGetting Started
CardPageLinkPreview Rollout
Preview Rollout
Provides controls for how the volume grid effect is displayed in the viewport.
Textboxcard
CardPageLinkRendering Rollout
Rendering Rollout
Provides controls for how the volume grid effect is rendered.
