width60%
VrayVFBVRayVFB – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Deep output – Specifies whether to include this render element in deep images.
width5%
width35%
Image RemovedImage Added
Common Uses
The VRayMtlReflectIOR Render Element is useful for changing the appearance of Reflective elements after rendering in a compositing or image editing software.
