Section | ||||||||||||||||||||||
Common Uses
The The Object ID Render Element is useful for isolating geometry in a scene based on the Object ID. This means that items can be isolated by use of a matte, created from the solid colors within the Object ID pass. In the example below the sofa This method is used to isolate and color correct the ottoman in the example. The ottoman has an Object ID of 1, the dangling light floor has an Object ID of 4 and the sideboard has walls have an Object ID of 2.
See how the render looks before and after compositing.
Before after | ||||||||||||||||||||
Fancy Bullets | ||
