Common uses
The The VRayRenderID Render Element is useful for isolating geometry in a scene. This means that items can be isolated by use of a matte created from the solid colors within the VRayRenderID pass. Exact RGB values for any object in the scene can be looked up, if the XML report is saved.
Column | ||
Column | ||
In the example, the leather ottoman is selected using the Render ID RE, and it is color corrected. See the render before and after compositing.
Before after | ||||||||||
width | 40% |
Render ID Render Element with Use node handle enabled
Column | ||
