These settings will be moved to the main render settings in a future release.
UI Expand | |||||||||||||||||
||Render Setup window|| > Render Elements tab > Add button > VRayOptionRE
Section | |||||||||||||||||||||
Anchor | ||||
The data in OpenEXR metadata attributes are of the format attr1=val1;attr2=val2;... where the values can be either integer or floating-point numbers, or lists of numbers in brackets representing vectors, matrices, etc. For example:
Code Block |
int_attr=53;float_attr=3.14;vec4_attr=(1, 2, 3, 4) |
