Please make sure that your system fulfills these requirements before installing V-Ray. Note that V-Ray is only supported for 64 bit operating systems and 64 bit versions of Maya.
Processor
IntelIntel®1 64, AMD64 or compatible processor with SSE4.2 support
RAM
4 GB RAM and 4 GB swap minimum – recommended 8 GB or more RAM, 8 GB or more swap file;
(Actual amount required will vary with scene requirements.)
USB PortRequired for customers using legacy hardware lock, preferably USB 2.0
TCP/IPOnly IPv4 required for distributed rendering is supported. IPv6 is currently not supported
GPU Acceleration
NVIDIA CUDA: Maxwell-, Pascal-, Volta-, Turing- and Ampere-based NVIDIA card(s) with with latest recommended video driver;
NVIDIA RTX: RTX cards with latest recommended video driver ;
V-Ray Production Denoiser: AMD or NVIDIA GPU supporting OpenCL 1.2;
NVIDIA AI Denoiser: Maxwell, Pascal, Volta, Turing or Ampere-based NVIDIA card with latest recommended video driver
Anchor
1.1
1.1
The minimum required compute capability is 5.22
The following table shows the versions of Autodesk Maya and operating systems on which V-Ray is supported. Note that V-Ray is only supported for 64 bit operating systems and 64 bit versions of Maya.
Version of Maya Supported Operating System
Maya 2019Windows ® 8.1, Windows ® 10 Professional, and Windows® 11
Maya 2020Windows ® 8.1, Windows ® 10 Professional, and Windows® 11
Maya 2022Windows ® 10 Professional and Windows® 11
Maya 2023Windows ® 10 Professional and Windows ® 11
Linux
Processor
1st Gen Intel® Core™64, AMD64 or compatible processor with SSE4.2 support (x64)
RAM
USB PortRequired for hardware lock, preferably USB 2.0
TCP/IPOnly IPv4 is supported. IPv6 is currently not supported
GPU Support
NVIDIA CUDA: Maxwell-, Pascal-, Volta-, Turing- and Ampere-based NVIDIA card(s) with latest recommended video driver;
NVIDIA RTX: RTX cards with with latest recommended video driver
The minimum required compute capability is 5.21
Maya 2019Red Hat ®  Enterprise Linux® 6.5 and 7.2 WS, or CentOS 7.2
Maya 2020Red Hat ®  Enterprise Linux® 7.3, 7.4, 7.5, 7.6, 7.7 WS, or CentOS 7.3, 7.4, 7.5, 7.6, 7.7
Maya 2022
Red Hat® Enterprise Linux® 8.2, 7.6-7.9 WS, or CentOS 8.2, 7.6-7.9
Maya 2023Red Hat® Enterprise Linux® 8.2, 7.6-7.9 WS, or CentOS 8.2, 7.6-7.9
macOS
Processor
1st Gen Intel® Core™ Intel® 64, AMD64, ARM 3 or compatible processor with SSE4.2 support (x64)
RAM
UI Text Box
sizemedium
typewarning
 V-Ray GPU works only with C++/CPU devices under macOS. V-Ray GPU can still be used in distributed rendering where a macOS machine runs the CUDA engine on a CPU device together with Windows/Linux machine(s) running CUDA engine on GPU device(s).
Version of Maya
Supported Operating Systems
Maya 2019Apple ® macOS ® 10.14, 10.13, 10.12 and 10.11.x
Maya 2020Apple® macOS® 11.x, 10.15.x, 10.14.x, 10.13.x
Maya 2022
Maya 2023
Apple® macOS® 12.x, 11.x, 10.15.x, 10.14.x
* The Autodesk Maya system requirements can be found here page: http://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/System-requirements-for-Autodesk-Maya.html
Fancy Bullets
typecircle
1Windows 11 is required for running Intel Alder Lake processors.
2CUDA compute capability and card reference
3. – ARM support for versions prior to and version Maya 2023 is translated through Rosetta.
  • V-Ray for Maya 2022 supports Python 3 by default. Builds with Python 2 support are available in the stable folder of the nightly server.
  • V-Ray 5 update 1.2 supports MayaUSD 0.8.0 (bundled in Maya 2022), MayaUSD 0.9.0, MayaUSD 0.10.0 (bundled in Maya 2022.1), MayaUSD 0.11.0 (bundled in Maya 2022.2) and MayaUSD 0.12.0.
  • V-Ray 5 update 2 supports MayaUSD 0.13.0 in addition to the previously supported versions.
