Section | |||||||||||||||||||||||||||||||||||||||||||
Anchor | ||||
Example: Invert Value
This example shows how the Invert value option can be used to push all colors in the Reflect IOR render element into the 0.0-1.0 range, and also how to determine the IOR values right within the V-Ray Frame Buffer. In each image, the values are sampled using the Show Pixel Information option in the VFB Toolbar.
Section | |||||
Fancy Bullets | ||
