This page gives details on how the physical sun and sky system works in V-Ray.
Section | ||||||||||||||||
UI Expand | |||||||||||||||||||||||||||
Anchor | ||||
Anchor | ||||
Section | |||||||||||||||||||||||||||
Section | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Anchor | ||||
Anchor | ||||
Anchor | ||||
Example: Sky Model
This example shows the different Sky models. The sun's position is close to the horizon and all other parameters are at their defaults. For more information on the PRG Clear Sky model, see the Improved Sun and Sky courseware page.
Shadows
Example: Shadow Bias
In the example renders below, the common settings are Intensity multiplier: 1, Size multiplier: 3.0, while the Shadow bias is the only attribute adjusted between renders. The values shown in the example are highly exaggerated to help show the effect the Shadow bias has on the scene. The change in the shadow position is most noticeable on the front of the building below the roof line where the shadow cast by the roof recedes back toward the top left overhang of the roof as the Shadow bias value increases.
Options
Photon Emission
Example: Color Mapping Types
The following render examples show the impact the Color Mapping Types have on the Sun and Sky system. For more on color mapping types, please see the Color Mapping page.
Clouds
Anchor | ||||
Example: Ground Shadows
The following example shows the effect of the Ground Shadows option.
Before after | ||||||||||
Anchor | ||||
Anchor | ||||
Anchor | ||||
Anchor | ||||
Anchor | ||||
Anchor | ||||
Anchor | ||||
Anchor | ||||
Example: Contrails Time
Anchor | ||||
The frames in this animation show the Contrails time parameter with values ranging between 0 and 2.0, with a step of 0.2.
V-Ray Sky Texture
For more information on the Sky portion of the V-Ray Sun and Sky System, please see the Sky Map (VRaySky) page.
Fancy Bullets | ||
Anchor | ||||
References
Here is a list of links and references about the V-Ray Sun and Sky implementation, as well as general information about the illumination of the Sun.
Fancy Bullets | ||||||
