Section | |||||||||||||||
Section | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Example: Taper
When this parameter is set to 0.0, no taper is applied to the strands and they have the same thickness from root to tip. Higher values make the root wider and the tip thinner.
Variance
Distribution
Example: Distribution
Options
Tessellation
Variance
Distribution
Options
Example: Knots
Setting a low Knots value creates less segments in the fur and this does not allow the hair to bend properly. Higher values allow for a more natural curve of the fur.
Textures
