The Volumetric tab contains volumetric output settings and a parameter controlling the Heat Haze effect when the Render Mode is set to Volumetric Heat Haze.
Section | ||||||||||||||||
Anchor heatHaze heatHaze
heatHaze | |
heatHaze |
Example: Heat Haze
Heat haze adds refraction at each ray-marching step through the volume. This only affects the camera's view. Heat haze will not affect shadows cast through a volume.
Section | |||||||||||||||||||||||
