Section | ||||||||||||||||||||||
Example: VRscans Zone Mask
The renders below show how the Zone value defines which zone is to be painted in white:
Common Use
The VR Scans Zone Render Element is most commonly used to isolate a sub-material inside a V-Ray Scans Material and modify it in a compositing or editing software. See the render before and after editing.
Before after | ||||||||||||||||||||
Section |
Column | ||
width | 70% |
Panel | ||
Normal RGB render |
Panel | ||
Zone = 0 |
Panel | ||
Zone = 1 |
width | 15% |
