This page provides information on the Lens Effects layer found in the V-Ray Frame Buffer.
Section | |||||||||||||||||||||||||||||
Anchor | ||||
Anchor | ||||
Example: Size
Section | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Anchor | ||||
Section | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Anchor | ||||
Example: Intensity
Anchor | ||||
Example: Cold/Warm & Saturation
Aperture Shape
Anchor | ||||
Example: Streak blur
Lens Scratches
Lens Dust
Obstacle Image
Anchor | ||||
Example: Obstacle Images
Size (constant) = 50
Bloom (constant) = 0.5
Chromatic Aberration
Aperture Preview
Anchor | ||||
Example: Chromatic Aberration Strength
Depending on the Strength of the chromatic aberration, you can create different looks in your scene. You can imitate the effect of a real camera with subtle aberration, or, if you wish to achieve an artistic effect, consider increasing the Strength parameter, as in the example.
Aperture Preview
File Names of Saved Channels
