Button | Description |
Starts Production Rendering with the current V-Ray renderer (V-Ray or V-Ray GPU). | |
Starts an Interactive Production Rendering (IPR) session with the current V-Ray renderer (V-Ray or V-Ray GPU). Found by clicking and holding the Render Current Frame / Production Mode button. | |
Opens the V-Ray virtual frame buffer (VFB). | |
Render in Chaos Cloud button opens the Submit to Chaos Cloud rendering dialog. | |
Shows the V-Ray light lister tool. | |
Creates a VRayPhysicalCamera. Click and drag in a viewport to actually create the camera. | |
Creates a rectangle VRayLight. Click and drag in a viewport to create the light. | |
Creates a dome VRayLight. Click in a viewport to create the light. | |
Create a sphere VRayLight. Click and drag in a viewport to create the light. | |
Creates a mesh VRayLight(s) out of the currently selected object(s). | |
Creates a VRayIES light. Click and drag in a viewport to create the light. | |
Creates a VRaySun light. Click and drag in a viewport to create the light. | |
Creates a VRayAmbientLight. Click in a viewport to create the light. | |
Creates a VRayProxy object. Click in a viewport to create the object. | |
Creates a VRayMetaball object. Click in a viewport to create the object. | |
Creates a VRayPlane object. Click in a viewport to create the object. | |
Applies VRayDisplacementMod modifier to the selected object. | |
Creates a VRayFur object over the currently selected object. | |
Creates a new VRayMtl material, assigns it to the selected objects and opens the new material in the Material Editor. For the classic Material Editor, the new material is shown in the currently selected slot. For the Slate Material Editor, the new material is shown in the middle of the Slate workspace. Clicking and holding this button opens a flyout with additional material types. | |
Creates a new VRaySSS2 material, assigns it to the selected objects and opens the new material in the Material Editor. Found under the V-Ray Material button. | |
Creates a new VRayHairNextMtl material, assigns it to the selected objects and opens the new material in the Material Editor. Found under the V-Ray Material button. | |
Creates a new VRayALSurfaceMtl material, assigns it to the selected objects and opens the new material in the Material Editor. Found under the V-Ray Material button. | |
Creates a new VRay2SidedMtl material, assigns it to the selected objects and opens the new material in the Material Editor. Found under the V-Ray Material button. | |
Creates a new VRayBlendMtl material, assigns it to the selected objects and opens the new material in the Material Editor. Found under the V-Ray Material button. | |
Opens the V-Ray Asset Browser and downloads its material library (if not already downloaded) for 3ds Max 2018 and above. For earlier 3ds Max versions, this button downloads the library but V-Ray Asset Browser's UI is not supported. The V-Ray material library can be loaded in the Material Editor from the Material/Map Browser. | |
Applies matte shadow settings through the V-Ray Object Properties on the selected object(s). | |
Registers the V-Ray menus - equivalent to the registerVRayMenus() MaxScript command. See Notes below. | |
Opens the V-Ray for 3ds Max online documentation. |
