||Select NURBS surface|| > Attribute Editor > Attributes menu > VRay > (select attribute set)
NURBS Attributes
Section | |||||||||||||||||||||||||
Object ID
Allows the user to give unique object IDs to your objects so that you can create selection masks using the Multimatte render element.
