This page provides information on the Translucent Two-Sided Material.
Section | |||||||||||||||
UI Path:
Section | |||||||||||||||||
Example: Translucency Value (Front vs. Back Material)
In every pyramid, there is a VRayLight (Sphere type), which are the only light sources in the scene.The setup of the VRay2SidedMtl includes a VRayMtl in the Front Material slot, and Check-Box Off. That means V-Ray will use the same material for the Back one as well. The VRayMtl (Front material) has a diffuse Bitmap and for the opacity - a procedural Output map.
Example: Usage examples
These are some examples of common usage for the V-Ray 2-sided Material
Fancy Bullets | ||
