width45%
V-Ray Interactive is an interactive rendering engine for SketchUp. To start using V-Ray Interactive, you can simply left-click the Interactive button from the main Asset Editor. You can always toggle the V-Ray Interactive renderer by clicking the Interactive switch in the Renderer rollout.
UI Text Box
typetip
Using the Interactive render will change the settings in both the central and advanced panel of the Asset Editor. For reference, see the Settings page.
width5%
width50%
UI Paths
width15%
width30%
||V-Ray Frame Buffer|| > Start Interactive Rendering
 ||V-Ray Asset Editor|| > Render with V-Ray (dropdown menu) > Render with V-Ray Interactive
width5%
width35%
 ||V-Ray for SketchUp Toolbar|| > Render Interactive
SketchUp Menus Ribbon
||Extensions|| > V-Ray  > Rendering > Render Interactive
width15%
