Right-click anywhere in the Batch Render window to open the context menu.
Add Current Model – Adds all views of the current model to the Batch Render.
Open Output Image – Opens the rendered image with the default image viewer.
Open Output Folder – Opens the folder in which the selected image has been saved.
Delete – Deletes the selected view.
Delete All – Deletes all loaded views.
width
5%
width
35%
Image Modified
width
60%
Options
Override Output Path – Sets a common output location for all files in the batch. If disabled, each output image is saved in its respective project file location. The render output file path specified in the V-Ray's settings is not respected in either case.
File Format – Allows the selection of different output types (.png, .jpg, .bmp, .tga, .hdr, .sgi, .rgb, .rgba, .exr, .pic, .tif, .tiff, .vrimg).
Render – Enables V-Ray to render the image to the frame buffer and then save an output image file.
Export VRScene – Enables V-Ray to export the scene to a .vrscene file.
Render and Export VRScene – Enables V-Ray to both render the image and export a .vrscene file.
width
5%
width
35%
Image Modified
Using V-Ray Batch Render in Chaos Cloud
Fancy Bullets
type
circle
Enable or disable a view from rendering by ticking the checkbox.
width
35%
width
30%
Image RemovedImage Added
width
35%
Animation, default viewport views, cameras and named views have different icons for easier differentiation.
.vrscene files can be loaded and rendered using Batch Render. Batch Render can also load a sequence of .vrscene files located in the same directory as long as they follow the same index enumeration, e.g. file_01.vrscene, file_02.vrscene, file_03.vrscene and NOT file_1.vrscene, file_02.vrscene, file3.vrscene, etc. When selecting a file that is part of a valid sequence, a dialog window prompts you to choose whether to load the whole sequence or the singe file. If a file sequence is available, the Batch Render tool does not apply an additional index to the render output files.
When aborting a Batch Render job, the current project's V-Ray render output file path is substituted by an invalid one. Upon finishing a Batch Render job, the last active project's output file path is substituted in the same way. This is a known limitation. To avoid it, initiate Batch Render jobs always in a new project and upon completion avoid saving the currently loaded one. Loaded .vrscene files are unaffected.
When the View option from Rendering tab of the Rhino Properties Panel is manually specified, it overrides the render output.
