This section contains details about Ray-Traced Textures found in V-Ray for Rhino.
HideElements | ||
Ray-Traced Textures provide some important scene data for use in compositing, such as particular distances and ratios.
A Ray-Traced Texture can be replaced with another Ray-Traced Texture or any other type of V-Ray texture via the Replace With New Texture (
) button, which activates when you select the texture to be replaced. If the texture is an instance, all copies are changed as well.
Section | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Thumbnailspagesettings ThumbnailOverlayRectangleColour 0,0,0 ThumbnailBGImageHeight 250px ThumbnailTextColour White ThumbnailTitleTextSize 22px ThumbnailOverlayRectangleHeight 22%
