Floatingpagetoc
This page provides information about the supported .vrscene features exported from V-Ray for 3ds Max.
UI Text Box | ||
Chaos Vantage has better support for .vrscene files exported from V-Ray Next, V-Ray 5. |
Lights
UI | Native name | V-Ray plugin name (plugin/parameter) | Support | |
Standard 3ds Max light
| On | enabled | |
Light Type: Spot Directional Omni |
LightSpotMax LightDirectMax LightOmniMax |
Targeted | – | |||
Shadows | shadows | |||
Use Global Settings | use_global_light_level | |||
Shadow Type Adv. Raytraced Area Shadows Shadow Map Ray Traced Shadows VRayShadow |
Exclude... | SettingsLightLinker/ignored_lights SettingsLightLinker/ignored_shadow_lights | |||
Transparent shadows | – | |||
Bias | shadowBias | |||
Area shadow: Box Sphere |
shadowShape=0 shadowShape=1 |
U size | shadowRadius | |||
V size | shadowRadius1 | |||
W size | shadowRadius2 | |||
Subdivs | shadowSubdivs | |||
| Multiplier | intensity | ||
Color | color | |||
Decay Type: None Inverse Inverse Sqaure |
decay_type=0 decay_type=1 decay_type=2 |
Decay Start | decay_start | |||
Near Attenuation: Use Show Start End |
near_attenuation – near_attenuation_start near_attenuation_end |
Far Attenuation: Use Show Start End |
far_attenuation – far_attenuation_start far_attenuation_end |
Show Clone | – | |||
Overshoot | overshoot | |||
Hotspot/Beam | hotspot | |||
Falloff/Field | fallsize | |||
Cirle | shape_type=0 | |||
Rectangle | shape_type=1 | |||
Aspect | rect_aspect | |||
Bitmap Fit... | – | |||
Contrast | – | |||
Soften Diff. Edge | – | |||
Diffuse | affectDiffuse | |||
Specular | affectSpecular | |||
Ambient Only | – | |||
Map | projector_map | |||
Object Shadows: Color Density Map Light Affects Shadow Color |
shadowColor – – – |
Atmosphere Shadows: On Opacity Color Amount |
V-Ray Lights
| V-Ray Light | |||
On | enabled | |||
Type: Plane Dome Sphere Mesh Disk |
LightRectangle/is_disc=0 LightDome LightSphere LightMesh LightRectangle/is_disc=1 |
Targeted | – | |||
Length/Radius | u_size | |||
Width | v_size | |||
Units: Default (image) Luminous power (lm) Luminance (lm/m2/sr) Radiant power (W) Radiance (W/m2/sr) |
units=0 units=1 units=2 units=3 units=4 |
Multiplier | intensity | |||
Mode: Color Temperature |
Color | color | |||
Temperature | color | |||
Texture | LightRectangle/use_rect_tex LightDome/use_dome_tex LightMesh/use_tex | |||
Texture Map | LightRectangle/rect_tex LightDome/dome_tex LightMesh/tex | |||
Res | tex_resolution | |||
| Directional | LightRectangle/directional | ||
Preview: Selected Always Never |
Preview texmap | – | |||
| Spherical (full dome) | LightDome/dome_spherical | ||
Affect alpha | LightDome/affect_alpha | |||
Lock texture to icon | – | |||
Ray dist: None From GI Explicit |
LightDome/dome_rayDistanceMode=0 LightDome/dome_rayDistanceMode=1 LightDome/dome_rayDistanceMode=2 |
Distance | LightDome/dome_rayDistance | |||
Target radius | – | |||
Emit radius | – | |||
Adaptive dome | LightDome/dome_adaptive | |||
Flip normals | – | |||
Pick mesh | LightMesh/geometry | |||
Replace mesh with light | – | |||
Extract mesh as node | – | |||
Exclude | SettingsLightLinker/ignored_lights SettingsLightLinker/ignored_shadow_lights | |||
Cast shadows | shadows | |||
Double-sided | doubleSided | |||
Invisible | invisible | |||
No decay | noDecay | |||
Skylight portal | lightPortal=1 | |||
Simple | lightPortal=2 | |||
Store with irradiance map | storeWithIrradianceMap | |||
Affect diffuse | affectDiffuse | |||
Diffuse contribution | diffuse_contribution | |||
Affect specular | affectSpecular | |||
Specular contribution | specular_contribution | |||
Affect reflections | affectReflections | |||
Shadow bias | shadowBias | |||
Cutoff | cutoffThreshold | |||
V-Ray IES Light | LightIESMax | |||
Enabled | enabled | |||
Enable viewport shading | – | |||
Show distribution | – | |||
Targeted | – | |||
Ies file | ies_file | |||
Rotation X | – | |||
Rotation Y | – | |||
Rotation Z | – | |||
Use light shape: No For shadows only For illumination and shadows |
soft_shadows=0 soft_shadows=1 soft_shadows=2 |
Override shape | ies_light_shape | |||
Shape | ies_light_shape | |||
Height | ies_light_height | |||
Width | ies_light_width | |||
Length | ies_light_length | |||
Diameter | ies_light_diameter | |||
Color mode: Color Temperature |
Color | color | |||
Color temperature | color | |||
Override inter: rescale replace |
override_prescribed_power=0 override_prescribed_power=1 |
Intensity type: power (lm) intensity (cd) |
Intensity value | power | |||
Area speculars | area_speculars | |||
Viewport wire color | – | |||
Icon text | – | |||
V-Ray Ambient Light | LightAmbientMax | |||
Mode: Direct + GI Direct light GI |
mode=0 mode=1 mode=2 |
GI min distance | gi_min_distance | |||
Color | color | |||
Intensity | color | |||
Light map | – | |||
Compensate exposure | compensate_exposure | |||
V-Ray Sun | SunLight | |||
Intensity multiplier | intensity_multiplier | |||
Size multiplier | size_multiplier | |||
Filter color | filter_color | |||
Color mode: filter direct override |
color_mode=0 color_mode=1 color_mode=2 |
Sky model: Preetham et al. CIE clear CIE overcast Hosek et al. Improved |
sky_model.0 sky_model=1 sky_model=2 sky_model=3 sky_model=4 |
Ground albedo | ground_albedo | |||
Indirect horiz illumination | horiz_illum | |||
Blend angle | blend_angle | |||
Horizon offset | horizon_offset | |||
Turbidity | turbidity | |||
Ozone | ozone | |||
Cast atmospheric shadows | atmos_shadows | |||
Photon emit radius | photon_radius |
Physical Camera
UI | Native name | V-Ray Plugin name | Support | |
Max Camera
| Physical Camera | CameraPhysical | ||
Targeted | – | |||
Target Distance | target_distance | |||
Show Cone: When Selected Always Never |
Show Horizon Line | – | |||
Texture Resolution | bmpaperture_resolution | |||
Use Lens File | distortion_type=2 | |||
Lens File | lens_file | |||
Preset | – | |||
Width | film_width | |||
Focal Length | focal_length | |||
Specify FOV | specify_fov | |||
FOV | fov | |||
Zoom | zoom_factor | |||
Aperture | f_number | |||
Use Target Distance | targeted=1 | |||
Custom | targeted=0 | |||
Focus Distance | focus_distance | |||
Lens Breathing | – | |||
Enable Depth of Field | use_dof | |||
Shutter Type | – | |||
Duration | shutter_speed | |||
Offset | shutter_offset | |||
Enable Motion Blur | use_moblur | |||
Exposure Control | SettingsColorMapping/exposure | |||
Manual | ISO | |||
Target | – | |||
Illuminant | white_balance | |||
Temperature | white_balance | |||
Custom | white_balance | |||
Enable Vignetting | vignetting | |||
Amount | vignetting | |||
Aperture Shape: Circular Bladed |
blades_enable=0 blades_enable=1 |
Blades | blades_num | |||
Rotation | blades_rotation | |||
Custom Texture | bmpaperture_tex | |||
Affect Exposure | bmpaperture_affects_exposure | |||
Center Bias (Ring Effect) | center_bias | |||
Optical Vignetting (Cat Eye) | optical_vignetting | |||
Anisotropy (Anamorphic Lens) | anisotropy | |||
Lens Shift: Horizontal Vertical |
horizontal_offset vertical_offset |
Tilt Correction: Horizontal Vertical |
horizontal_shift lens_shift |
Auto Vertical Tilt Correction | – | |||
Distortion Type: None Cubic |
distortion=0 distortion_type=1 |
Amount | distortion | |||
Texture | lens_file | |||
Enable | RenderView/clipping | |||
Clipping Near | RenderView/clipping_near | |||
Clipping Far | RenderView/clipping_far | |||
Environment Near Range | – | |||
Environment Far Range | – | |||
V-Ray Camera
| V-Ray Physical Camera | CameraPhysical | ||
Targeted | – | |||
Camera Type: Still cam Movie cam Video cam |
type=0 type=1 type=2 |
Target distance | target_distance | |||
Focus distance | focus_distance | |||
Show cone | – | |||
Show horizon line | – | |||
Use Field of view | specify_fov | |||
Field of view | fov | |||
Film gate (mm) | film_width | |||
Focal length (mm) | focal_length | |||
Zoom factor | zoom_factor | |||
Film speed (ISO) | ISO | |||
F-Number | f_number | |||
Shutter speed | shutter_speed | |||
Shutter angle | shutter_angle | |||
Shutter offset | shutter_offset | |||
Latency (s) | latency | |||
Depth of field | use_dof | |||
Motion blur | use_moblur | |||
Exposure: No exposure Physical exposure Exposure value (EV) |
exposure=0 exposure=1 exposure=2 |
Exposure value | exposure_value | |||
White balance | white_balance | |||
Custom balance | white_balance | |||
Temperature (K) | white_balance | |||
Automatic vertical tilt | – | |||
Tilt: Vertical Horizontal |
lens_shift horizontal_shift |
Shift: Vertical Horizontal |
vertical_offset horizontal_offset |
Guess vert tilt | – | |||
Guess horiz tilt | – | |||
Enable Blades | blades_enable | |||
Center bias | center_bias | |||
Anisotropy | anisotropy | |||
Optical vignetting | optical_vignetting | |||
Bitmap aperture | bmpaperture_enable | |||
Affect exposure | bmpaperture_affects_exposure | |||
Bitmap resolution | bmpaperture_resolution | |||
Bitmap | bmpaperture_tex | |||
Distortion type: Quadratic Cubic Lens file Texture |
distortion_type=0 distortion_type=1 distortion_type=2 distortion_type=3 |
Lens file | lens_file | |||
Map | distortion_tex | |||
Clipping | RenderView/clipping | |||
Near clipping plane | RenderView/clipping_near | |||
Far clipping plane | RenderView/clipping_far | |||
Near env range | – | |||
Far env range | – | |||
Mode: Disabled Top to bottom Bottom to top Left to right Right to left |
rolling_shutter_mode=0 rolling_shutter_mode=1 rolling_shutter_mode=2 rolling_shutter_mode=3 rolling_shutter_mode=4 |
Duration (s^-1) | rolling_shutter_duration |
Geometry
Native Name | V-Ray Plugin Name | Support |
V-Ray Clipper | VRayClipper | |
V-Ray Displacement | GeomDisplacedMesh GeomStaticSmoothedMesh | |
V-Ray Fur | GeomHair | |
V-Ray Instancer | Instancer | |
V-Ray MetaBall | – | |
V-Ray Plane | GeomPlane | |
V-Ray Proxy | GeomMeshFile | |
V-Ray Scene | VRayScene | |
V-Ray Sphere | – | |
V-Ray VolumeGrid | PhxShaderSimVol |
Materials
Tabs Page | |||||||||||||||||||||||||||||||||||||||
VRayMtl
Tabs Page | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Maps
Column | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
