The LightSunV-RaySun and Sky texture are special features which are provided by the V-Ray renderer. Developed to work together, the V-Ray Sun and Sky system reproduces the real-life sun and sky environment of the Earth. Both are coded so that they change their appearance depending on the direction of the VRaySunthe V-Ray Sun.
For easier workflow, LightSun V-Ray Sun and Sky creates an all-set-and-ready-to-use Sun and Sky system in Cinema 4D.
More information on the LightSun V-Ray Sun parameters can be found at on the V-Ray Sun page.
More information on the VRaySky texture parameters can be found at on the VRaySky page.
UI Path: ||V-Ray|| > Lights > V-Ray Sun with Sky
width
50%
Image Removed
Image Added
width
50%
width
5%
width
50%
width
57%
The V-Ray Sun and Sky system in Cinema 4D introduces an easy way to manage both the V-Ray Sun and the Sky texture together.
When created, V-Ray automatically sets a V-Ray Dome lightwith a LightSun and LightSunV-Ray Sun and V-Ray Sun-Target under it in the Objects tab.
The LightSunV-Ray Sun-Target is a dummy object created in the viewport, that you can use to control the direction of the Sun.
UI Text Box
type
note
Rotating the LightDome Dome Light object rotates the whole LightSun V-Ray Sun and Sky system!
width
5%
width
38%
width
57%
The Sky texture is automatically attached as a the Dome Tex.
For more information on the Sky texture, see the V-Ray Sky page.
width
5%
width
38%
width
33%
If you want to change the pivot point of the Sun with another object, you can do the following:
Go to the Target tab under LightSunthe V-Ray Sun;
With the selector of the Target Object, choose the desired object.
