Official release
Date - 23 Feb, 2021
Release Notes: V-Ray 5
UI Button | ||||||||||
Align | ||
SPEED YOUR WORKFLOW
With V-Ray Vision you can enjoy a realistic real-time view of your model while you work. You can walk around to get a better sense of your design and take better decisions. You can see your design evolve instantly as you apply materials or setup lights, allowing for rapid iterations. You can quickly produce pictures and even export 360 panoramas to speed up the approval process. And whenever you are ready to present your design to your clients, you can easily scale your model to photoreal quality.
See V-Ray Vision
ELEVATE YOUR MODEL TO PERFECTION
Now, V-Ray for Revit comes with a brand new curated asset library - Chaos Cosmos, that helps you better tell your story. Easily create real-world context for your model’s interior and exterior by adding high-quality entourage from the essential categories - furniture, accessories, lighting, vegetation, vehicles and people. Search and import straight from within V-Ray and spend zero time on setup - Cosmos assets have accurate physical scale, automatic levels of detail, and are ready to be rendered. Chaos Cosmos provides a consistent 3D content experience across Chaos products and renderers.
EXPLORE LIGHTING LIKE NEVER BEFORE
With the new Light Mix feature, you can experiment with all the light sources in your model after you have rendered. Group your lights, tweak their brightness or change their color to find what best fits your space.
See LightMix
POST-PROCESS INSIDE REVIT
Our redesigned Frame Buffer comes with powerful new features that take you beyond just rendering. You don’t need a separate app for compositing or color corrections — they can be handled with V-Ray and saved as presets for future projects.
See Layers
SKETCH YOUR IDEAS WITH A CLICK
The new global Contours setting helps you give a sketch-like look to your concepts. Apply them to the whole model automatically or use them selectively to highlight certain objects.
See Contours
STREAMLINED PROXY MATERIAL SETUP
We've simplified the proxy material assignment process with the V-Ray Asset Editor. Assign materials in the Editor once, save them along with the mesh file and you can reuse this configuration in any project.
ADD REALISM TO REVIT MATERIALS
Now Displacement is not limited only to V-Ray materials — it’s an asset of its own that’s easy to apply to native materials.
See Displacement
MORE CREATIVE FREEDOM WITH THE SUN & SKY
Studying your design’s interaction with natural light has never been easier. With more control over the sky generation parameters and access to our improved sky model, your sunrises and sunsets will never look better.
See V-Ray Sun
RANDOMIZE TEXTURES FOR REALISM
Use the UVW Placement asset to randomize patterns and colors of V-Ray materials as they would appear in the real world.
See UVW Placement
COAT & SHEEN LAYERS
Quickly create polished surfaces of your materials with the new Coat layer. Utilize the new Sheen layer to create realistic fabrics such as velvet, satin or silk.
See Coat Layer and Sheen Layer
DIRT & WEATHERING
Add weathering effects to any surface of your model with the improved V-Ray Dirt texture.
See Dirt Texture
IMPROVED MATERIAL LIBRARY
Save time by downloading our render-ready Material library, containing over 500 high-resolution 4K textures such as glass, metal, wood and many more.
