width60%
The Sheen Filter Render Element is analogous to the Reflection Filter Render Element.
The Sheen Filter RE stores reflection information calculated from the VRayMtl Sheen Layer. Surfaces with no Sheen values set in its material(s) contain no information in the render pass and therefore render as black.
While the Raw Sheen Reflection RE gives the full reflection of objects reflecting in the scene, Sheen Filter RE shows how much of that reflection should come through in the composite. In other words, the filter defines the strength of the reflection, while the raw reflection channel defines what is being reflected in the image. When these two elements are multiplied, the true level of reflection is given and produces Sheen Reflection RE. Using these component parts of the reflection, you can better fine tune the reflection in your final composite.
UI Expand
titleUI Path: ||Render Setup window|| > Render Elements tab > Add button > VRaySheenFilter
Image Modified
width5%
width35%
Image RemovedImage Added
width60%
VRayVFB – When enabled, the render element appears in the V-Ray Frame Buffer.
Color mapping – Applies the color mapping options specified in the Color mapping rollout (Render Setup window > V-Ray tab) to this render element. This option is enabled by default.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
width5%
width35%
Compositing Formula
Multiplying the V-Ray Sheen Filter by the V-Ray Raw Sheen Reflection, produces the V-Ray Sheen Reflection.
Image Added
