changes.mady.by.user Gergana Lilkova
Saved on Jul 11, 2022
changes.mady.by.user Kristina Gaytandzhieva
Saved on Jan 25, 2023
The Sheen Glossiness Render Element is analogous to the Mtl Reflect Glossiness Render Element. This channel holds a float number with the value set in the Sheen Glossiness parameter in the VRayMtl Sheen Layer.
Image RemovedImage Added
VRayVFB – When enabled, the render element appears in the V-Ray Frame Buffer.
Image Modified
