This page provides information on the Coat Reflection Render Element.
Section | |||||
Section | |||||||||||||||
Common Uses
Fine-tuning the Coat Reflections
Applying the Coat Filter RE and the Raw Coat Reflection RE to the composition in Multiply blend mode produces Coat Reflection RE. This method is used to allow for better fine-tuning of the coat reflections in the scene. However, for general purposes, the Coat Reflection RE produces sufficient results.
Enhancing the Coat Reflections
You can enhance the coat reflections of your composition by including the Coat Reflection RE in Add mode inside the VFB. Increasing the render element's contrast further accentuates the reflections. In this example, the effect is applied only in areas selected with a Cryptomatte mask. See how the composition changes after enhancing.
Before after | ||||||||||
