Show Box | showgrid – Shows the bounding box of the Simulator. The green outline is drawn based on the settings in the Grid rollout while the red outline displays the bounds of the currently loaded cache file.
Graph Cells | gridcells – Shows  – Shows a lattice with the cell sizes on the sides of the Simulator's box or the Slice Preview.
Show Mesh | show mesh – When enabled, shows the Isosurface as a mesh. The Isosurface  is defined in the Surface section of the Rendering rollout. This mode overrides the Voxel Preview mode. Note that if Mode is set to Ocean Mesh in the FireSmoke Rendering settings, the surface is generated in the viewport with low mesh resolution in order not to slow down the user interface significantly.
