The Raw Refraction Render Element is a color image that stores refraction information calculated from materials' refraction values in the scene. Surfaces with no refraction values set in their materials contain no information in the render element, and therefore will render black.
Note: To properly calculate the Raw Refraction Render Element, the Refraction Render Element must also be added to the list of render elements being calculated during the rendering process to properly determine all the refraction information in the scene.
width
5%
width
35%
Image Removed
UI Expand
title
UI Path: ||Render Setup window|| > Render Elements tab...
||Render Setup window||> Render Elements tab > Addbutton > VRayRawRefraction
Image Added
width
20%
5%
width
60%
35%
Image Modified
width
20%
width
60%
VrayVFB– When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Color mapping – Applies the color mapping options specified in theColor mapping rollout of the V-Ray tab in the Render Setup window to this render element. This option is enabled by default.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
Denoise – Specifies whether to denoise this render element.
