V-Ray Material Library is designed to cover detailed resolution for your realistic renders. V-Ray Material Library Browser eases navigation in this library by providing high quality material previews, content filtering and quick search of the hundreds of materials available.
Each material can be assigned to an object by drag-n-drop (using either left-mouse or middle-mouse button) into the viewport. Materials Materials can also be drag-and-dropped into the Hypershade or anywhere in Maya's viewport.
Note that when installing from a .zip, the V-Ray Material Library is not automatically downloaded. See See how to download it manually below.
width
5%
width
45%
UI Expand
title
UI Path: ||V-Ray Shelf|| > V-Ray Material Library
UI Path: ||V-Ray Shelf|| > V-Ray Material Library button
Image RemovedImage Added
width
35%
UI Path:V-Ray Menu > V-Ray Material Library Browser
Image AddedImage Removed
width
5%
width
60%
With middle-mouse button drag-n-drop the material over an object to assign it
