Floatingpagetoc
CSS Stylesheet
.rwui_text_box {
margin:0px;
@media only screen and (min-width:1550px) {
iframe {
max-width: 600px;
text-align:right;
Responsivegridmacro
VAlignmentstart
Columns3width1290px
Columns1width1540px
Columns2width1290px
This page provides information on the Live Link feature from SketchUp in Chaos Vantage.
Div
classRespColumnsHeader
width45%
The Live Link feature makes it possible to instantly see changes made in SketchUp without the need to export and import .vrscenes in Chaos Vantage.
width55%
Align
alignright
HTML
<iframe width="560" height="350" src="https://www.youtube.com/embed/7fndXZOpDvY" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Live Link Setup
For Live Link to function properly, please follow the steps below:
Installation
UI Text Box
typenote
Live Link works only with V-Ray 5 for SketchUp, update 2 or later versions.
width50%
1. Download and install the latest official V-Ray for SketchUp build from the download button. Make sure you have appropriate licenses. If you experience problems, please contact Chaos Support using the online form.
width5%
width45%
Align
alignright
UI Button
colorblue
newWindowtrue
icondownload
titleDownload V-Ray for SketchUp
urlhttps://download.chaosgroup.com/?platform=56&product=47
width50%
2. Download latest Chaos Vantage build from the download button. Make sure you have appropriate licenses. If you experience problems, please contact Chaos Support using the online form.
width5%
width45%
Align
alignright
UI Button
colorblue
newWindowtrue
icondownload
titleDownload Chaos Vantage
urlhttps://download.chaosgroup.com/?platform=47&product=63
After installation, Live Link can be initiated in one of the following 2 ways:
Start Chaos Vantage
width50%
 Use the Start Chaos Vantage in SketchUp. It can be accesses either from:
Fancy Bullets
typecircle
    • the Start Chaos Vantage button in the Chaos Vantage toolbar which is hidden by default but can be enabled from View > Toolbars > Chaos Vantage
    • the Start Chaos Vantage command accessible from Extensions > V-Ray > V-Ray Live Link
Using either of the two initializes a live link session between SketchUp and Chaos Vantage. It automatically:
Fancy Bullets
typecircle
    • Starts Chaos Vantage if it is not already running;
    • Sends the scene to Chaos Vantage on 20701 port ;
    • When clicked again, closes the Live Link connection.
width5%
width45%
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/qhLWHdI4gq0?list=PLm2Irfq-UvZ3h2Sxw2FVd9qjOIpqHOLiG" title="Using Live Link from SketchUp to Chaos Vantage" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
width50%
Start a Custom Live Link session in SketchUp.
Expand
titleClick here to expand for manual Live Link setup
In Sketchup:
width100%
1. Open the Customize Live Link dialogue by going to Extensions > V-Ray > V-Ray Live Link > Customize Live Link:
1.1 Specify the following :
Fancy Bullets
typecircle
  • Address – add your local machine as as server. Enter either localhost or 127.0.0.1
  • Port – specify a port range for which Chaos Vantage awaits incoming data. By default it is 20701
1.2 Close the Customize Live Link dialogue by clicking the OK button.
In Chaos Vantage:
width50%
1. Open Chaos Vantage.
width5%
width45%
width60%
2. Open the Live Link menu and make sure Start Server is enabled (greyed out). If Start Server on Application Start is enabled, every time Chaos Vantage is launched in stand-by mode and waits for incoming data.
width5%
width35%
Vantage_LiveLinkStartServer.pngImage Modified
width60%
3. Setup port range in Change Port.. menu and make sure the range entered here matches the one previously set SketchUp. Default is 20701.
width5%
width35%
Vantage_Livelink_port.PNGImage Modified
Back In Sketchup:
width100%
Start Live link by going to Extensions > V-Ray > V-Ray Live Link > Start Custom Live Link.
width5%
width45%
width50%
Once a Live Link session is started, the scene is transferred to Chaos Vantage and a thick blue contour line appears around the viewport and the status message in the lower right changes to [LIVE LINK]
UI Text Box
typeinfo
The Pause when app loses focus option in the Preferences menu is ignored when in Live Link session.
To stop a Live Link session, either click again the Start Chaos Vantage button, Start Custom Live Link option, or open the VFB and stop the Interactive rendering.
width5%
width45%
Vantage_HeroImage Modified
Supported Features
The following changes made in SketchUp are propagated through Live Link:
Fancy Bullets
typecircle
  • Editing, creating and deleting of:
    • Camera
    • Geometries
    • Lights
    • Materials
    • Textures
    • Environment
Excerpt Include
Live Link Setup
Live Link Setup
nopaneltrue
