CSS Stylesheet
.UIImage {
max-width:900px;
margin-left:auto;
margin-right:auto;
This page provides information on setting up Chaos Vantage through a silent installation and removing it through a silent uninstallation.
A silent installation allows you to complete Chaos Vantage installation without user input during the process using a predefined set of options. To set up a silent installation, you need to perform two steps: creating an .xml file and running the installer.
You can remove Chaos Vantage from your machine similarly through a silent uninstall.
Installer Arguments
You can run the installation file from command prompt with the following arguments:
-helpPrints available arguments for the installer executable.
-configFile
Specifies path to an installation configuration file.
-gui
Specifies if a Graphic User Interface or a command line one will be is used during installation:
0 – No Graphic User Interface is visible, installation is in command line.
1 – Installation is with a Graphic User Interface.
-debugSpecifies the level of debug logging by the installer. Defaults to 0 and assumes a value of 1 if argument is provided with no value.
-autoSpecifies if the installation is automatic with default settings and forces the -quiet argument.
-quiet
Specifies whether the automatic installation is without user input. Defaults to 1.
0 – Installation requires user input and asks for a confirmation of each variable before proceeding. It also prints log in the console.
1 – Installation is without user input. EULA is accepted automatically.
-backup
Specifies whether the  installer performs backup on previous installation.
0 – Previous installation is not backed up.
1 – Previous installation is backed up.
Creating the .xml file
Run the installation file from the command prompt with the -gui=0 argument.
e.g. vantage_1.6.2.exe -gui=0
Follow the instructions of the install and set - up the installation the way you want to have it on all machines. This creates a file named config.xml in the folder of the installation file.
Running the installer
In the second step, you run the installer with the following command:
vantage_1.6.2.exe -gui=0 -configFile="xml_file.xml" -quiet=1 -auto
Configuration File
The config.xml file holds configuration information about the settings of the installation. Below is an example of such a config file.
Example installer config XML file: ChaosVantageSilentInstall.xml
Code Block
<DefValues>
 <Value Name="DESKTOP_SHORTCUT" DataType="value">1</Value>
 <Value Name="REGISTRY_PROG_ID" DataType="value">Chaos.Vantage</Value>
 <Value Name="STDROOT" DataType="value">C:\Program Files\Chaos Group\Vantage</Value>
 <Value Name="REMOTE_LICENSE" DataType="value">0</Value>
 <Value Name="DESKTOP_PATH" DataType="value">C:\Users\USER_NAME\Desktop</Value>
 <Value Name="REVERT_INSTALL" DataType="value">1</Value>
 <Value Name="ASSOCIATE_VANTAGE" DataType="value">1</Value>
 <Value Name="FIREWALL_EXCEPTION" DataType="value">1</Value>
 <Value Name="INSTALL_TYPE" DataType="value">0</Value>
 <Value Name="PROGRAMFILES" DataType="value">C:\Program Files</Value>
 <Value Name="APPDATALOCAL" DataType="value">C:\Users\USER_NAME\AppData\Local</Value>
 <Value Name="INSTALL_CGLS" DataType="value">1</Value>
 <Value Name="REVERT_UNINSTALL" DataType="value">0</Value>
 <Value Name="STARTMENUPROG" DataType="value">C:\ProgramData\Microsoft\Windows\Start Menu\Programs</Value>
 <Value Name="COMMONFILES" DataType="value">C:\Program Files\Common Files</Value>
 <Value Name="SEND_USER_FEEDBACK" DataType="value">1</Value>
 <LicServer>
  <Host>127.0.0.1</Host>
  <Port>30304</Port>
  <Host1></Host1>
  <Port1>30304</Port1>
  <Host2></Host2>
  <Port2>30304</Port2>
  <User></User>
 </LicServer>
</DefValues>
UI Text Box
typenote
Please note that USER_NAME is specific for the currently logged user.
Below is a description of the common variables that can be defined in the .xml file:
DESKTOP_SHORTCUT
Specifies whether a desktop shortcut for Chaos Vantage is created:
0 - No desktopr desktop shortcut for Chaos Vantage is created.
1 - Creates a desktop shortcut for Chaos Vantage.
REGISTRY_PROG_ID
Specifies how Chaos Vantage is added in the windows registry. Default is Chaos.Vantage.
STDROOT
Specifies the installation folder for Chaos Vantage. Default location is C:\Program Files\Chaos\Vantage.
UI Text Box
typenote
Note that for versions prior to Vantage 2.5, the default location is C:\Program Files\Chaos Group\Vantage
REMOTE_LICENSE
Specifies whether the Chaos license server runs locally or on another machine:
0 - The license server runs locally on the same machine.
1 - The server is on a different machine in the network.
DESKTOP_PATH
Specifies the desktop folder path where the desktop shortcut of Chaos Vantage is generated. Default location is C:\Users\USER_NAME\Desktop.
REVERT_INSTALL
Specifies whether the installation is reverted and copied files are deleted if errors occur that prevent the install process to continue:
0 - Copied files are not deleted if errors occur.
1 - Copied files are deleted if errors occur.
ASSOCIATE_VANTAGE
Specifies whether .vantage files are assosiated associated and opened from the windows explorer with Chaos Vantage:
0 - .vantage files are not assosiated associated and cannot be opened from the windows explorer with Chaos Vantage.
1 - .vantage files are assosiated associated and can be opened from the windows explorer with Chaos Vantage.
FIREWALL_EXCEPTION
Specifies whether to add a Firewall Exception for the Chaos license server:
0 - Does not add a Firewall Exception for the Chaos license server.
1 - Adds a Firewall Exception for the Chaos license server.
INSTALL_TYPE
Specifies the installation type:
0 – Workstation.
PROGRAMFILES
Specifies the Program files folder location. Default location is C:\Program Files.
APPDATALOCAL
Specifies the local Application data folder location. Default location is C:\Users\USER_NAME\AppData\Local.
INSTALL_CGLS
Specifies whether to install the Chaos license server:
0 - Does not install Chaos license server.
1 - Installs the Chaos license server.
REVERT_UNINSTALL
Specifies whether the uninstall is reverted and installed files are not deleted if errors occur that prevent the uninstall process to continue:
0 - Installed files are deleted if errors occur.
1 - Installed files are not deleted if errors occur.
STARTMENUPROG
Specifies the Start menu programs folder location. Default location is C:\ProgramData\Microsoft\Windows\Start Menu\Programs.
COMMONFILES
Specifies the windows' Common files folder location. Default location is C:\Program Files\Common Files.
SEND_USER_FEEDBACK
Controls whether the user feedback system will be is used:
0 – Disables user feedback system.
1 – Enables user feedback system.
<LicServer>
This section specifies the client license settings.
<Host>IP_Address</Host>
Primary license server's IP Address.
<Host1>IP_Address</Host1>
Alternate license server's 1 IP Address.
<Host1>IP_Address</Host2>
Alternate license server's 2 IP Address.
