Code Block |
{"status":"success","type":"analyze step"} {"status":"success","type":"validate step"} {"jobID":"IwuTUGmU6ydVBVyD","jobName":"toyota-chr","jobURL":"https://cloud.chaos.com/jobs/IwuTUGmU6ydVBVyD","message":"Job created.","type":"output"} {"message":"Uploading started.","type":"info","uploadSize":"0.00B"} {"type":"progress","progress":100} {"jobID":"IwuTUGmU6ydVBVyD","jobURL":"https://cloud.chaos.com/jobs/IwuTUGmU6ydVBVyD","message":"Scene uploaded successfully. Job ID: IwuTUGmU6ydVBVyD\nCheck the rendering progress on https://cloud.chaos.com/jobs/IwuTUGmU6ydVBVyD","type":"output"} {"type":"progress","progress":0} {"type":"progress","progress":5} {"type":"progress","progress":6} {"type":"progress","progress":20} {"type":"progress","progress":42} {"type":"progress","progress":79} {"type":"progress","progress":99} {"type":"progress","progress":100} {"message":"job IwuTUGmU6ydVBVyD is completed","jobId":"IwuTUGmU6ydVBVyD","state":"completed","type":"output"} {"message":"Rendering finished, downloading outputs...","type":"output"} {"message":"Downloading output for job 'IwuTUGmU6ydVBVyD' (586.72KB)","sizeString":"586.72KB","type":"output"} {"type":"progress","progress":0} {"type":"progress","progress":59} {"type":"progress","progress":60} {"type":"progress","progress":100} {"type":"progress","progress":100} {"message":"downloaded output of job IwuTUGmU6ydVBVyD successfully","type":"output"} |
Status Check
Clone Only Incomplete Frames
The --onlyUncompleted flag of the job resubmit command clones only frames from a job, that are not in a complete state - failed, canceled or paused frames.
Code Block |
$ ccloud --json job resubmit --id="IbJD218cTrXcO1Ps" --onlyUncompleted |
Code Block |
{"message":"Job Ixd3TAudUv5eWBgb is started successfully from IbJD218cTrXcO1Ps","newJobID":"Ixd3TAudUv5eWBgb","type":"output"} |
Status Check
Completed Job
Code Block |
$ ccloud --json job status --id DEll0jabB7AOoTc0 |
Code Block |
{"jobID":"DEll0jabB7AOoTc0","message":"job DEll0jabB7AOoTc0 is completed","state":"completed","type":"output"}
Active Job
Code Block |
$ ccloud --json job status --id DElti15NpajRV9K0 |
Code Block |
{"jobID":"DElti15NpajRV9K0","message":"job DElti15NpajRV9K0 is active (0%)","progress":"0%","state":"active","type":"output"} |
Failed Job
Code Block |
$ ccloud --json job status --id DEll0jabB7AOoTc0DElti15NpajRV9K0 |
Code Block |
{"jobID":"DEll0jabB7AOoTc0DElti15NpajRV9K0","message":"job DEll0jabB7AOoTc0DElti15NpajRV9K0 is completedfailed","state":"completedfailed","type":"output"} |
Active Job
Uncompleted Frames
Code Block |
$ ccloud |
job status --id |
="IxZdIu9mWqlQRsQn" |
Code Block |
"message":"job |
IxZdIu9mWqlQRsQn is |
paused, not all frames were completed."," |
jobId":" |
IxZdIu9mWqlQRsQn"," |
Failed Job
Code Block |
Code Block |
{"jobID":"DElti15NpajRV9K0","message":"job DElti15NpajRV9K0 is failed"frames":[{"state":"paused","frameRange":"1-100"}],"state":"failedpaused","type":"output"} |
Downloading Completed Jobs
