Mode – This parameter specifies the mode for the compositing backplate.
Backplate – This mode allows using a backplate (real-world photo). Environment – This mode allows using a Corona Sky or C4D Sky object as the environment.
Backplate – This slot allows you to set the backplate.
UI Text Box
type
note
The backplate parameter is only available when the Mode is set to Backplate.
Environment – This slot allows to specify the environment object (either a Corona Sky or a standard C4D Sky object can be used here).
Projection mode – This parameter controls how to handle projection for secondary (reflected) rays that hit the material. This generally needs to be set to correspond with the backplate projection (simple backplate or 360° enviro map) to get correct reflections of the shadow catcher on the scene object.
UI Text Box
type
note
The environment and projection modes are available only if the Mode is set to Environment.
Alpha mode – This parameter controls how the shadow catcher is displayed in the alpha channel. Available modes are:
Fancy Bullets
Always solid – Resulting alpha channel is always solid/white.
For compositing – The resulting alpha channel is affected by the shadow projection. The area covered by shadows results in a solid white/gray alpha (depending on the intensity of the shadow), while the surface area that has no shadows projected on it results in a black/transparent alpha.
Always transparent – Resulting alpha channel is always black/transparent.
UI Text Box
type
info
Using the For compositing option also makes the shadow catcher black for direct rays, which is required for correct workflow.
UI Text Box
type
info
When the Alpha Mode is set to For compositing, the directly visible color of Shadow catcher material is overridden to black. To compose the render correctly, make sure to override the directly visible environment color to black as well.
Shadow amount – This parameter controls how much light is bounced off the shadow catcher onto other objects (a relative value). Increasing the value forces less light bouncing, therefore making shadows darker.
width
5%
width
45%
Image Removed
width
50%
Project backplate options
Use scene environment for off-screen rays – When enabled, this parameter uses scene environment for off-view rays when using a simple backplate.
Off-screen – This parameter is used to load a texture map or shader for off-view rays when using a simple backplate.
UI Text Box
type
note
The off-screen parameter is only available if the "Use scene environment for off-screen rays" option is disabled.
width
5%
width
45%
Image Added
Reflection
width
50%
Use matte projection mode – When enabled, all texture maps use the camera projection specified by the Projection mode above. When disabled, only the Environment/Backplate slot uses it and others are not projected.
Level – This is the intensity (also considered as the visibility) of the reflection color.
Color – This is the color used for reflections.
Texture – This slot defines the texture map or shader that are used instead of the above color.
Mix mode – This parameter controls the blending mode of the texture map or shader over the color.
Mix strength – This value controls the intensity of the texture map or shader that is being used.
width
5%
width
45%
Image Removed
Fresnel IOR
width
50%
Value – This value controls the amount of material reflection in a physically plausible way. Higher values create stronger reflection.
Texture – This slot defines the texture map or shader that will be used to control the Fresnel IOR.
width
5%
width
45%
width
50%
Glossiness
Value – This value controls how sharp or blurred the reflection is. A value of 1 gives completely sharp reflections, while a value of 0 gives completely blurred reflections.
Texture– This slot defines the texture map or shader that will be used.
width
5%
width
45%
Image Added
Bump
width
50%
Strength– This value defines the bump level.
Texture– This slot defines the texture map or shader used to control the Bump.
