This page provides information on the Corona Legacy Material.
width
50%
Corona Legacy Material is an updated name for the Corona Material which used to be the default material in Corona 6 and older. Corona Physical Material is the new default starting with Corona 7.
UI Text Box
type
warning
In Corona 7 and newer both the Corona Physical Material and the Corona Legacy Material are available, however the Corona Legacy Material is only kept to ensure compatibility with older scenes. In Corona 7 and newer there is no need to use the Corona Legacy Material and it is best to use the new Corona Physical Material instead.
width
5%
width
45%
width
48%
Decorative elephant prop with glossy wood material controlled with bitmaps
width
4%
width
48%
Candles using wax material with Volumetric Scattering enabled
