This page provides information on the Corona Round Edges Map.
width
50%
The Corona Round Edges Map produces a render-only rounded edges shading effect on hard edges of geometry and in the areas where two or more objects or object elements intersect. To apply this effect, connect a Corona Round Edges Map to a material's bump slot.
The typical use cases include smooth metal materials applied to low-poly meshes, architectural concrete, soft stucco finish.
UI Text Box
type
note
The Corona Round Edges Map affects shading only. It does not really smooth or chamfer the edges of the geometry it is applied to.
