This page provides information on the Corona Color Map, its settings, and usage.
Corona Color is a simple map that outputs the user-defined color. The color values can be defined using 3ds Max Color Selector or Corona Color Picker, HDR RGB values, Kelvin temperature, and Hexadecimal code.
The output value can also be multiplied and its alpha can be specified. Input can be set to either gamma-corrected or linear color space.
Section | |||||||||||||||||||||
