This page provides information on the Corona Front Back map, its settings, and usage.
Floatingpagetoc |
Corona Front Back map is a simple map allowing you to assign different colors/maps to a surface based on the orientation of the normal (front face / back face). This is useful, for example, for backface culling when used in the Opacity slot, or for assigning print to the front of a label on a bottle, and plain paper on the back of the same label (seen through the glass of the bottle).
