Multiexcerpt | |||||||||||||||||||
Interface
The License Server's interface is accessible in a web browser. See the License Server Interface page for more information.
Unified Login Application (ULA)
With V-Ray 6, the Unified Login Application is integrated in the License Server installation. The ULA allows Single Sign On for all ULA integrated Chaos desktop apps. For example, signing in any of the Chaos applications, will automatically log the user in all other Chaos applications installed on the machine.
Installation
The installer is fairly straightforward and easy to run, but if you need help, please see the Installing the License Server page for details on the process. This includes using your Chaos account to access your purchased licenses from anywhere online.
In most situations, adjusting the Settings for the online licensing system is not necessary. But if you need to adjust something like your connection settings because you're using a Proxy server, you can get to these through the drop-down menu in the top right corner of the License Server webpage and choosing Settings. For more details on what settings are adjustable from this area, please see the Advanced Settings page.
Updating
the Chaos License Server
If you are updating your licensing system from the previous setup to the new online system, no changes are required on the workstation or application side of your software. The online system replaces the existing dongle functionality without any additional steps needed on your part. There is no need to use the Change License Settings application to reconfigure your setup. If you have purchased online licenses, these can be activated for online usage in the new system right away.
UI Text Box | ||
The username and password credentials in the Change your license settings tool window are not the same as your online credentials used to log into your account at my.chaosgroup.com and activate the License Server. |
Section | |||||||||||||||||
