This is article provides a list of command-line options that can the Corona Benchmark can be used with.
Floatingpagetoc |
The table below lists all command-line options that the Corona Benchmark can be used with:
Option | Alias | Description |
--start | -s | Runs the Benchmark without the need to press the "Start" button. |
--repeat=<num-of-times> | -r | Runs the Benchmark given number of times and prints average, minimum, and maximum statistics to the console. If not given, not the average, but final statistics of one run of Benchmark is printed to the console. |
--save=<directory> | Saves the results of the Benchmark to the given directory (created if doesn't exist). In combination with --repeat argument, saves the statistics on each run and the final average of statistics (average of the scores and the CPU frequencies per run). | |
--submit | In combination with --repeat submits the average statistics. | |
--stressTest | Runs the Benchmark infinitely without the possibility to submit results. | |
--help | -h | Prints help information. |
--version | Shows application version and information. |
Examples
Run the Benchmark and start rendering without the need to press the "Start" button: Windows:
macOS:
Run the Benchmark, start rendering without the need to press the "Start" button, repeat the benchmarking process 3 times, and save the results of each run (including the minimum, maximum, and the final average of the scores) to the specified folder: Windows:
macOS:
