Official release
Date – 2017
Download Build – 1.0
Key Features
- Measurement of CPU and CUDA GPU V-Ray rendering performance
- Benchmark.chaosgroup.com site section for comparing benchmark results against other hardware
- Single executable that runs without Administrative privileges and without Internet connection
- Free software - V-Ray license is not required
- High DPI support
Known Issues
- OS UI may be sluggish during GPU benchmark
- GPU CUDA devices could be enabled/disabled from nVidia Control Panel only
- If there is a proxy present, you should:
1. LAN Settings > Bypass proxy server for local addresses - should be turned on
2. Set environment variables HTTPS_PROXY and HTTP_PROXY before benchmarking
