© Taichi Kobayashi
« Previous Version 2 Next »
This page gives an overview of the Specular Render Element and explains how it is used.
The Specular Render Element isolates the reflected light in the scene. This render element is an image that stores specular reflection (highlight) information calculated from the material's reflection value in the scene. Specular reflection is defined as the reflection of light from a surface in a single particular reflection, as opposed to a diffuse reflection which is reflected at many angles.
The brighter the area, the more highlight reflection the object exhibits in the render. Specular highlights will be colored if the Reflection Color parameter of a material is colored.
UI Path
||out Network|| > V-Ray Render Elements node > V-Ray > Render Channel > Color Channel > Type > Specular
Attributes
The parameters for this render element appear in the V-Ray RenderChannelColor render channels node.
Denoise – Enables the render element's denoising, provided the Denoiser render element is present.
Consider for Anti-Aliasing – When enabled, anti-aliasing will be used where possible.
Filtering – Applies the image filter to this channel. Image filter settings are in the Image Sampler tab of the Sampler tab of the  V-Ray Renderer node.
Color Mapping – When enabled, the Color Mapping options in the render settings will be applied to the current render channel.
VFB Color Corrections – Applies the post render color adjustments made from the VFB.
Evaluating the Specular Render Element
In most scenes, the Specular Render Element will render as mostly black with some gray, or as completely black. Only materials that are set up to reflect, and which do actually reflect a highlight in the rendered scene, will be rendered as having image value in the render element. Shades of gray (or shades of color) in the Specular Render Element rarely reach full value (white in most cases); a white or full value pixel would indicate that the material is completely made up of reflected light at that point, which is rare in realistic scenes. Surfaces with no reflection values set in their material(s) will contain no information in the render element, and will therefore render as black.
Specular light primarily appears on reflective surfaces with a low incidence angle to a bright surface or light source. Lowering the material's gloss value below 1.0 or increasing the IOR can increase this effect.
Common Uses
The Specular Render Element is useful for changing the final image's specular appearance during compositing. Below are a couple of examples of its use.
Original Beauty composite
Brightened, Blurred and Tinted Specular Render Element
Brightened and blurred Specular Render Element
Tinted Specular
Brightened, blurred & tinted Specular set to screen mode in composite
Underlying Compositing Formula
The Specular Render Element is added as part of the Beauty composite to form the final image.
