© Bertrand Benoit
« Previous Version 2 Next »
Latest Release Notes
Official Release
Date – August 29, 2019
New Features
V-Ray
  • Moved to CORE version 4.20
  • Render resolution and Lightmap Atlas resolution presets
  • Lightmap baking progress bar
Geometry
  • Support for Cast Shadows option for Static Mesh Actors
Textures
  •  Support for "Flip Green Channel" option in Normal textures
Modified Features
Import
  • Improved the import of GeomMeshFile with identical vrmeshes
Installer
  • Removed the check for running Epic Games launcher when installing the plugin
Materials
  • Improved support for Unreal expressions - VertexColor, ObjectRadius, ObjectPositionWS
Bug Fixes
V-Ray
  • Static Meshes with zero area UVs cause an Exception in CORE error when light baking
  • Camera rotation bug when orbiting around mesh with ALT+Mouse
  • Resolution capped to 11585
  • Assertion crash with viewport rendering when using DX12
  • Preparing scene progress goes above 100%
  • Switching between level maps does not stop rendering or baking process
  • Two Sided option not exporting correctly with VRayMtl, VRayCarpaintUberMtl, VRayPBRMtl
Release Notes for V-Ray Next for Unreal, update 2.1
Official Release
Date – July 18, 2019
Bug Fixes
V-Ray
  • V-Ray Light Bake memory leak
  • Issue with support of multiple GPUs
  • Issue with transparent native materials in Light bake
Official Release
Date – June 26, 2019
New Features
V-Ray
  • Export/import functionality of lightmaps
Lights
  • Rendering of DatasmithAreaLight
Camera
  •  Quadratic and Cubic distortion types to VRayPhysicalCamera
Modified Features
V-Ray
  • Project path is new default directory for "Export VRScene Path" option
Lights
  • Point Light Source radius working in IPR
Materials
  • Improved support for Unreal expressions - TwoSidedSign, Time
Bug Fixes
V-Ray
  • Static meshes with identical names in different folders do not render correctly
  • Lights in Blueprints are exported at BP pivot point
  • "Use Local Host" option not working in Light bake
  • "Cannot send asset" error when in DR
  • Incorrect Lightmaps is applied when some level actors are hidden
  • CUDA Error 700 when "Export failed for the ... texture"
  • CUDA error 700 when baking TwoSidedFoliage material
  • "Error in last lightbake: File write error"
Release Notes for V-Ray Next for Unreal, update 1
Official Release
Date – May 28, 2019
New Features
V-Ray
  • Support for Unreal Engine 4.22
  • Toggle option for sky in VRaySunAndSky
  • Option to remove local host from DR
  • "Transfer Missing Assets" option in DR
  • Progress report logging when computing long task
  • Directional parameter in VRayLightRect
  • Light options to V-Ray Lights - Affect Diffuse, Affect Specular, Affect Reflections
  • Support for Specular Scale for Unreal lights
Modified Features
V-Ray
  • Viewport rendering with Translucent shading model
  • Speed and memory utilization when V-Ray Light Bake
  • Support for Unreal shading models - Subsurface, Two Sided Foliage
  • Support for Unreal expressions - Pixel Depth
  • UI layout in V-Ray Settings and V-Ray Light Bake Settings
Bug Fixes
V-Ray
  • Bug with lightmaps having offset
  • Performance slow down during UV tree preparation in V-Ray Light Bake
  • Crash in cooked games packaged in Shipping configuration
  • Issues with metallic or highly reflective materials to appear black after V-Ray Light Bake
  • Intensity mismatch between viewport and render when using Directional Light
Official Release
Date – March 13, 2019
New Features
V-Ray
  • Viewport rendering functionality
  • Support for Unreal tonemapper and post effects (in viewport rendering only)
  • Dedicated V-Ray Bake settings
  • Telemetry
Modified Features
V-Ray
  • Dome Tex Resolution parameter in VRayLightDome blueprint
  • Functionality for creating, deleting and hiding actors in the level while in IPR rendering
  • Support for "Tangent Space Normal" checkbox option in Material
  • Support for Unreal expressions: Arccosine, Arcsine, Arctangent, Arctangent2, Logarithm2, Tangent, World Position
Installer
  • Updated Online License Server in installer to 5.2.2
Bug Fixes
V-Ray
  • "Launch V-Ray Render Server (Unreal)".exe file path
  • Issue with Sky texture not updating in IPR
  • Issues when using Normal maps in Materials
Release Notes for V-Ray Next for Unreal, Hotfix 3
Official Release
Date – February 01, 2019
New Features
V-Ray
  • Support for rendering Unreal materials with V-Ray Hybrid rendering on both CPU and GPU
  • Added the VRayMtl, VRayPBRMtl and VRayCarpaintMtl to the V-Ray Category in the Add New drop down menu in the Content Browser
Modified Features
V-Ray
  • Support for Unreal Shading Models: Clear Coat
  • Interactive update for native Unreal materials.
  • Support for Unreal expressions: Bump Offset, CameraPositionWS, ConstantBiasScale, ReflectionVectorWS, Screen Position, SphereMask, TransformVector, VertexNormalWS, ViewProperty
  • Error reporting for unsupported Unreal materials, expressions, blend modes and shading models
Installer
  • Updated Online License Server in installer to 5.2.1
Bug Fixes
V-Ray
  • Errors due to NVidia driver dependencies
  • Crashes if unsupported expressions, blend modes and shading models are used
Release Notes for V-Ray Next for Unreal, Hotfix 2
Official Release
Date – December 05, 2018
Modified Features
V-Ray
  • Support for Unreal Engine 4.21
  • Support for Unreal expressions - Ceil, Floor, FMod, Frac, If, Min, Round, Sign, Truncate expressions
Light Bake
  • Improved speed of light bake
Bug Fixes
V-Ray
  • V-Ray exporter in sequencer
    • Export for custom start frame
    • Export for sequencer camera cuts using multiple cameras
    • Difference in color space in VFB and saved image
    • VRay CUDA GPU Device Select not working with sequencer animation
Release Notes for V-Ray Next for Unreal, Hotfix 1
Official Release
Date  November 15, 2018
Modified Features
V-Ray
  • Responsiveness of UI during interactive render
Light Bake
Installer
  • Updated Online License Server in installer to 5.1.2
Teleport Blueprint
  • Updated Teleport BP to get exposure from listed cameras
Bug Fixes
V-Ray
  • V-Ray not loading in Unreal if no supported devices are set in device select
    • Fallback to using CPU device if no supported devices are set in device select
  • Render Server shortcut not pointing to correct file path
Light Bake
  • Light bake not using devices set in V-Ray CUDA GPU Device Select
  • CUDA error during light baking
Official Release
Date  November 08, 2018
New Features
V-Ray
  • Log V-Ray messages in Unreal's Message Log
  • Basic support for importing Displaced Static Meshes
  • Output a list of the Static Meshes in the atlas currently baked
Modified Features
V-Ray
  • Support for Unreal Materials - Masked, Translucent, Alpha Composite Blend Modes and Unlit Shading Model
Bug Fixes
Light Bake
  • Crash when light baking Static Meshes with overlapping UVs
Release Notes for V-Ray Next for Unreal, beta 2
Beta release
Date – October 30, 2018
New Features
Light Bake
  • Initial implementation of V-Ray Bake
Materials
  •  Initial support for Unreal native materials
Geometry
  • Support for Foliage system
Render
  • Initial support for Sequencer animation
Modified Features
Installer
  • Request confirmation about version being uninstalled during installation process
UI
  • Reworked UI
  • Integrated GPU device select tool in V-Ray Settings
  • Global Shadow Bias parameter
  • Fallback material for use when rendering unsupported materials
  • Quick settings quality presets slider
  • Export VRScene path option
  • Auto Exposure and Auto White Balance options
  • Undersampling option
Camera
  • Support for Depth of Field in VRayPhysicalCamera
Materials
  • Improve parity for VRayMtl material
  • Support for SeflIllumination material
  • V-Ray Materials are now included in the packaging/cooking process
Lights
  • Updated VRaySunAndSky sky model
  • Support for Unreal Intensity Units in Lights
  • Support for 4.20 RectLight
  • Support for Light Source Angle in Directional Light
  • Support for default intensity unit at import for Spotlight, Omni, Sphere Light, Rectangle Light
Geometry
  • Improved support for VRay Proxy (vrmesh)
Render
  • Update responsiveness and speed of IPR
  • Support for interactive mesh material update
  • Support for interactive material parameters update
  • Stop renderer when noise threshold is reached in non-interactive session
Render Elements
  • Added :
    • NVidia AI Denoiser
    • Background, GI, Lighting, Reflection, Refraction, Specular, Self Illumination, Sub Surface Scattering
    • Diffuse Filter, Reflection Filter, Refraction Filter, Shadows, Atmosphere
    • RenderID
    • Normals, Bump Normals, Sampler Info, Velocity, ZDepth
    • Light Select
    • Sample Rate, Unclamped Color, Noise Level
VFB
  • Dedicated button for opening the VFB
  • Always on top VFB
VR
  • V-Ray Teleport Blueprints separated in an additional plugin
Beta release
Date – April 05, 2018
New Features
vrscene Support
  • Automatic convert of materials and lights into real-time equivalents for UE workflows
  • Keeping original materials from the imported vrscene connected to their real-time versions and are using them for raytraced rendering
Camera
  • Support for the VRayPhysicalCamera
  • Support for the 3ds Max’s Physical Camera
  • Initial implementation of exposure and color mapping
Materials
  • Support for VRayMtl material (including partial VRay2SidedMtl)
  • Initial implementation of a PBR material
  • Initial implementation of an easy to use car paint material
  • V-Ray materials are supported natively in UE and are working with Lightmass baking, Lights, Reflection probes, Post process materials, Blueprints
Lights
  • Support for VRayLightDome, VRayLightRectangle, VRayLightSphere, VRayLightIES, UE Spot light, UE Point light, UE Direct light
  • Initial implementation of the V-Ray Sun&Sky system
Render
  • Initial implementation of interactive rendering
  • V-Ray Hybrid rendering on both GPU and CPU
  • Using the V-Ray Next GPU engine
Distributed Rendering
  • Support for DR
Render Elements
  • Support for the V-Ray Denoiser
Textures
  • Support for VRayTriplanarTex
VFB
  • Support for the VFB
  • Render History window implemented
VR Mode
  • Support for the VR mode in the Unreal Editor
