© Taichi Kobayashi
« Previous Version 6 Next »
This page contains information about the V-Ray Cellular Texture.
The V-Ray Cellular Texture map generates a procedural cellular noise pattern.
UI Paths
||mat Network|| > V-Ray> Procedural Texture > V-Ray Celluar
 ||out Network|| > V-Ray Render Elements node > V-Ray > Procedural Texture > V-Ray Cellular
Node
The V-Ray TexCellular node provides inputs for controlling various texture properties. They correspond to parameters in the section below.
Type – Specifies which type to use for the Cellular texture. The choices are Dots, Chips, Cells, Chess Cells, or Plasma.
Background Color – Controls the color of the background of the Cellular procedural texture.
Center Color – Controls the color of the center of the cells.
Edge Color – Controls the color of the edges of the cells in the Cellular procedural texture.
Size – Controls the size of the Cellular procedural texture. For more details, please see the Size examples below.
Spread – Controls the spread of the procedural Cellular texture. For more details, please see the Spread examples below.
Density – Controls the Density of the Cellular texture. For more details, please see the Density examples below.
Low – Controls the low threshold (background color). For more details, please see the Low examples below.
Middle – Controls the middle threshold (edge color). For more details, please see the Middle examples below.
High – Controls the high threshold (center color). For more details, please see the High examples below.
Fractal – Enables the addition of fractal generation. Only available with Dots and Chips Types.
Fractal Iterations – Controls the number of fractal iterations. For more details, please see the Fractal Iterations examples below.
Fractal Roughness – Controls the roughness of the fractal. A value of 0.0 is very rough and a value of 1.0 is very smooth, which negates the fractal. For more details, please see the Fractal Roughness examples below.
Color Tweaks
Mult – Specifies a strength multiplier for the texture color.
Offset – Color corrects the texture by adding the the RGB color values specified here to the RGB color values in the texture.
Invert – When enabled, inverts the resulting texture color.
Alpha Tweaks
Source – Specifies where the alpha channel is drawn from.
Alpha – Alpha channel is drawn from the texture.
Color
– Alpha is generated from pixel intensity.
Opaque
– Alpha channel is fully opaque.
Use – Differentiate between textures exported from different applications. You can choose between Color Intensity (3ds Max) and Color Luminance (Maya).
Mult – Specifies a multiplier for the texture alpha.
Offset – Specifies an additional offset for the texture alpha.
Invert – When enabled and Invert from Color Tweaks is also enabled, the resulting texture alpha is inverted as well.
Placement
Placement Type – Specifies the way the valid portion of the texture is applied.
Full – Uses the full valid portion of the texture.
Crop – Allows the user to specify a section of the texture using the parameters below.
Place – Allows the user to specify a section of the texture and how to place it using the parameters below.
U – Specifies the U coordinate of the valid texture sector.
V – Specifies the V coordinate of the valid texture sector.
W – Specifies the width of the valid texture sector.
H – Specifies the height of the valid texture sector.
Jitter – Controls the amount of random placement variation.
Tile U – Enables horizontal tiling.
Tile V – Enables vertical tiling.
UV Noise
Enabled – Enables noise for the texture.
Amount – Specifies the amount of noise to add to the texture.
Levels – Specifies the amount of noise iterations.
Size – Controls the scale of the noise.
Animated – Enables the noise to be animated.
Phase – Controls the noise phase.
Example: Size
Dots Size: 0.05
 Dots Size: 0.1
Dots Size: 0.2
 Chips Size: 0.2
Chips Size: 0.35
 Chips Size: 0.5
Cells Size: 0.1
Cells Size: 0.2
Cells Size: 0.5
Chess Cells Size: 0.1
Chess Cells Size: 0.2
Chess Cells Size: 0.5
 Plasma Size: 0.05
Plasma Size: 0.07
Plasma Size: 0.2
Example: Spread
Dots Spread: 0.5
Dots Spread: 1.0
 Dots Spread: 1.5
Chips Spread: 0.5
Chips Spread: 1.0
 Chips Spread: 2.0
 Cells Spread: 0.1
 Cells Spread: 0.5
 Cells Spread: 1.0
Chess Cells Spread: 0.1
Chess Cells Spread: 0.5
 Chess Cells Spread: 0.9
 Plasma Spread: 1.0
Plasma Spread: 3.0
Plasma Spread: 5.0
Example: Density
Dots Density: 0.1
 Dots Density: 0.25
Dots Density: 1.0
Chips Density: 0.25
Chips Density: 0.7
Chips Density: 1.5
Cells Density: 0.15
Cells Density: 0.25
 Cells Density: 0.5
Chess Cells Density: 0.15
 Chess Cells Density: 0.25
Chess Cells Density: 0.5
Plasma Density: 0.5
 Plasma Density: 1.0
Plasma Density: 2.0
Example: Low
The Dots examples below use Size: 0.25, Spread: 0.5, and Density: 1.5. The Edge Color is blue for visual clarity
Dots Low: 0.0
Dots Low: 0.5
Dots Low: 1.0
The Chips examples below use Size: 1.0, Spread: 0.75, and Density: 3.0. The Edge Color is blue for visual clarity.
Chips Low: 0.0
Chips Low: 0.5
Chips Low: 0.9
Example: Middle
The Dots examples below use Size: 0.25, Spread: 0.5, and Density: 1.5. The Edge Color is blue for visual clarity.
Dots Middle: 0.0
Dots Middle: 0.5
Dots Middle: 1.0
Chips Middle: 0.0
Chips Middle: 0.5
Chips Middle: 1.0
Example: High
Dots High: 0.0
Dots High: 0.75
Dots High: 1.0
Chips High: 0.0
Chips High: 0.75
Chips High: 1.0
Example: Fractal Iterations
Fractal not enabled
Fractal Iterations: 1.75
Fractal Iterations: 3.0
Fractal not enabled
Example: Fractal Roughness
The Dots examples below use Size: 0.25, Spread: 0.5, Density: 1.5, and Fractal Iterations: 3.0.
Fractal Roughness: 0.0
Fractal Roughness: 0.5
Fractal Roughness: 0.9
The Chips examples below use Size: 1.0, Spread: 0.75, Density: 3.0, and Fractal Iterations: 3.0.
