« Previous Version 22 Next »
This page provides information on supported features in V-Ray for Cinema 4D based on the rendering type and hardware architecture.
Rendering
FeatureV-RayV-Ray GPU
Cinema 4D Team Render(error)(error)
Geometry
V-Ray Proxy(tick)(tick)
Displacement(tick)(tick)
V-Ray Fur(tick)(tick)
V-Ray Clipper(tick)(tick)
(without Mesh mode)
Lighting
Feature
V-RayV-Ray GPU
V-Ray Lights
(tick)
(tick)
Image-based lighting
(tick)
(tick)
Light and shadow linking
(tick)
(tick)
Cinema 4D Omni LightPARTIALPARTIAL
Cinema 4D Spot LightPARTIALPARTIAL
Cinema 4D Infinite LightPARTIALPARTIAL
Cinema 4D Area LightPARTIALPARTIAL
Cinema 4D IES LightPARTIALPARTIAL
Cinema 4D Sun LightPARTIALPARTIAL
Cinema 4D PBR LightPARTIALPARTIAL
Global Illumination Methods
Brute Force
(tick)
(tick)
Light Cache
(tick)
(tick)
Caustics(tick)PARTIAL 1
Render Elements
Preset: Back to Beauty(tick)(tick)
Atmospheric Effects(tick)(tick)
Background
(tick)
(tick)
Bump Normals
(tick)
(tick)
Caustics
(tick)
(Production mode)
(error)
Coat Specular(tick)(tick)
Coat Filter(tick)(error)
Coat Glossiness(tick)(error)
Coat Reflection(tick)(tick)
Coverage
(tick)
 (error)
Cryptomatte
(tick)
(Bucket sampling)
PARTIAL
Denoiser
(tick)
(tick)
Diffuse
(tick)
(tick)
GI
(tick)
(tick)
LightMix(tick)(tick)
Light Select
(tick)
(tick)
Lighting
(tick)
(tick)
Material ID(tick)(tick)
Material Select(tick)(error)
Matte Shadow(tick)(error)
Normals(tick)(tick)
Object ID(tick)(tick)
Object Select(tick)(error)
Raw GI(tick)(error)
Raw Light(tick)(error)
Raw Reflection(tick)(error)
Raw Refraction(tick)(error)
Raw Shadow(tick)(error)
Raw Total Light(tick)(error)
Reflect IOR(tick)(error)
Reflection Filter(tick)(tick)
Reflection Glossiness(tick)(error)
Reflection Highlight Glossiness(tick)(error)
Refraction(tick)(tick)
Refraction Filter(tick)(tick)
Refraction glossiness(tick)(error)
Render ID(tick)(tick)
SSS(tick)(tick)
Sample Rate(tick)(tick)
Self Illumination(tick)(tick)
Shadow(tick)(tick)
Velocity(tick)(tick)
Z Depth(tick)(tick)
Materials
Al Surface(tick)(tick)
Blend
(tick)
(tick)
Car Paint 2(tick)(tick)
Light
(tick)
(tick)
(without Opacity)
V-Ray Material
(tick)
(tick)
(without Translucency,
Diffuse Roughness)
Fast SSS2
(tick)
PARTIAL
(without raytraced (solid) and raytraced (refractive))
Hair Next(tick)(tick)
Bump
(tick)
(tick)
2 Sided
(tick)
(tick)
Scanned(tick)(tick)
Textures
VRayBitmap(tick)(tick)
VRayC4DBake(tick)(tick)
VRayCurvature(tick)(tick)
VRayDirt(tick)PARTIAL
VRayDistance(tick)(tick)
VRayFalloff(tick)(tick)
VRayFresnel(tick)(tick)
VRayLayered(tick)(tick)
VRaySky(tick)(tick)
VRayTriPlanar(tick)(tick)
Cinema 4D Shaders
Color
(tick)
(tick)
Fresnel
PARTIAL
PARTIAL
GradientPARTIALPARTIAL
Noise(tick)(tick)
Colorizer
BAKED
BAKED
Filter(tick)(tick)
Fusion
BAKED
BAKED
LayerPARTIALPARTIAL
Posterizer
BAKED
BAKED
Effects
Ambient Occlusion
(error)
(error)
Backlight
(error)
(error)
ChanLum
(error)
(error)
Distorter
(error)
(error)
Falloff
(tick)
(tick)
Lens Distortion
(error)
(error)
Lumas
(error)
(error)
Normal Direction
(error)
(error)
Normalizer
(error)
(error)
Pixel
(error)
(error)
Projector
(error)
(error)
Proximal
(error)
(error)
Ripple
(error)
(error)
Spectral
(error)
(error)
Spline
(error)
(error)
Subsurface Scattering
(error)
(error)
Terrain Mask
(error)
(error)
Thin Film
(error)
(error)
Variation
(error)
(error)
Vertex Map(tick)(tick)
Weathering
(error)
(error)
MoGraph
Beat Shader
BAKED
BAKED
Camera Shader
BAKED
BAKED
Color Shader
BAKED
BAKED
Multi Shader
BAKED
BAKED
Sketch and Toon
Art
BAKED
BAKED
Cel
BAKED
BAKED
Hatch
BAKED
BAKED
Spots
BAKED
BAKED
Surfaces
Brick
BAKED
BAKED
Checkerboard(tick)(tick)
Cloud
BAKED
BAKED
Cyclone
BAKED
BAKED
Display Color
BAKED
BAKED
Earth
BAKED
BAKED
Fire
BAKED
BAKED
Flame
BAKED
BAKED
Formula
BAKED
BAKED
Galaxy
BAKED
BAKED
Marble
BAKED
BAKED
Metal
BAKED
BAKED
Pavement
BAKED
BAKED
Planet
BAKED
BAKED
Rust
BAKED
BAKED
Simple Noise(tick)(tick)
Simple Turbulence
BAKED
BAKED
Starfield
BAKED
BAKED
Stars
BAKED
BAKED
Sunburst
BAKED
BAKED
Tiles
BAKED
BAKED
Venus
BAKED
BAKED
Water
BAKED
BAKED
Wood
BAKED
BAKED
Moves Face Shader
BAKED
BAKED
Polygon Hair
BAKED
BAKED
Substance Shader
BAKED
BAKED
Overrides
Material Override(tick)(tick)
Footnotes
Cinema 4D shaders marked as BAKED are supported by V-Ray via the Bake Cinema 4D Shaders option available in Render Settings > Overrides > Textures or via the VRayC4DBake texture.
 1. The new Progressive Caustics method works only with the Progressive Image Sampler and on CPU.
