« Previous Version 26 Next »
Download V-Ray for Cinema 4D
Build 5.10.23
Official release, update 1.3
Date - Oct 14, 2021
New features
  • Support for Cinema 4D R25
VRayTextures
  • Support TexRamp in material nodes
Modified features
V-Ray
  • Improve responsiveness when working with Node Materials
  • Add an option to hide QT framework warnings from the log
LegacySceneConverter
  • Better conversion for the "Material Weight" and "Use Fresnel" parameters from the classic V-Ray Advanced Material
Bug fixes
V-Ray
  • Fix slow export of cloners in render instance mode
  • Fix slow export of scenes with lots of material assignments
  • GPU device selection is not used if preferences are not open
  • Wrong viewport previews of node materials
  • Viewport previews don't render if editor map size is not default
  • Overridden editor map size in the preview settings of the material is considered even if "override preferences" is disabled
  • The "Save" and "Open" dialogs are not shown when the VFB is used on displays with different DPI scaling
  • Textures are black in the viewport when using Cinema4D layered shader
  • LightMix in manual light select mode does not work
V-Ray, Interactive
  • VFB layers are not saved when applied while Interactive is running
VRayProxy
  • Some Cosmos assets change their material when the object is expanded to geometry
VRayMaterials
  • V-Ray GPU crashes when rendering CarPaint 2 material in animation
Build 5.10.22
Official release, update 1.2
Date - Sept 02 2021
New features
V-Ray
  • Support for Chaos Cosmos
VRayTextures
  • Implemented V-Ray Normal Map texture
  • TexMix as classic shader and node added in the V-Ray node space
Modified features
VRayMaterials
  • Material viewport previews are slow even for constant colors
VRayTextures
  • Scenes load slowly with enabled material previews
V-Ray
  • Considers disabled motion blur from Cinema 4D tag
VRayProxy
  • Flip proxy z-axis to improve compatibility with other host applications with right-handed coordinate system
VRayLights
  • Ozone and Turbidity parameters in VRay Sky should be inactive when Sky Model is set to Improved
Bug fixes
V-Ray
  • Fixed wrong shadows casted by V-Ray Sun to Volumetric objects
  • Moving the VFB window causes the image inside to flicker
  • The Vertical Shift parameter in the Physical Camera does not work in Production rendering
Build 5.10.21
Official release, update 1.1
Date - Jul 27 2021
Modified features
V-Ray
  • Support for the VertexMap tag
Bug fixes
V-Ray
  • V-Ray doesn't render in the same color space as the Node materials
  • Geometry dissapears with V-Ray GPU Interactive rendering when using the CUDA engine
  • Opacity mask doesn't work if the "Tile" option is disabled
  • V-Ray doesn't render motion blur when using command line rendering with frame overrides
  • Node preview updates may not be triggered for ports of Layered and Blend nodes
  • Aborted update of texture node preview
  • Different animated visibility in V-Ray for Cinema 4D and Standalone
  • Animated visibility of objects does not work when exported and rendered with V-Ray Standalone
  • Fix artifacts with animated boolean geometry
  • Crash with animated boolean geometry when using default scene material
VRayProxy
  • Adding a scene containing proxy from the content browser doesn’t keep the materials applied
  • Rendering alembics is more than 3 times slower than rendering unpacked geometry on CPUs with many cores
Build 5.10.20
Date - Jun 23, 2021
New features
V-Ray
  • Add V-Ray node space for node materials
  • Add V-Ray Clipper as scene object
  • Add V-Ray Fur as scene object
  • Cryptomatte in progressive
  •  Progressive caustics mode
VRayVolumeGrid
  • Add Slice and Mesh preview options
VRayEnvironmentFog
  • Environment Fog colored transparency
VRayMtl
  • New translucency modes for VRayMtl (based on VRayScatterVolume)
  • Thin-walled refraction option
VFB
  • Now possible to change or remove VFB2 shortcuts
  • Layers masking based on Cryptomatte, integer and color render elements data
  • Added stamp layer support
  • Custom White Balance support for color picker and tint
  • Support for animated sequences for Background layer using <frameNum> tag
  • Added an option to bake the RGB primaries conversion
  • Added horizontal/vertical offset for Background layer
  • Image Info for the history images
  • Added the frame number to the VFB History image info overlay
  • Save color corrections to a LUT file
  • Added an option to switch between world units and pixels as photon lookup radius for the caustics photon map
VRayDomeLight
  • Support for multiple Dome lights for Light Mixing
V-Ray/vdenoise
  • Integrated Intel Open Image Denoiser
VRayRectLight, VRayLightSphere
  • Added "Occlude other lights" option for V-Ray lights
VRaySun/V-Ray GPU
  • Added support for blending the sun with the horizon with the Improved sky model
  • Added support for tiled textures with large amount of tiles on V-Ray GPU
  • Rounded corners, VRayDirt, VRayCurvature, VRayFastSSS2, VRayAlSurfaceMtl, VRayClipper support with Out-Of-Core geometry
V-Ray GPU
  • Added support for normal maps in world space
Modified features
V-Ray
  • Improve include/exclude object lists usage with hierarchies
  • Consider MotionBlur tag for disabling motion blur on objects
  • Faster initialization of meshes with static 3D displacement in Standalone
  • Mixed filtering option for ZDepth
  • Added preview modes to V-Ray Proxy object
  • Automatically load the full geometry when it's made editable
VRayTriplanar
  • Replaced the "scale" parameter of the VRayTriplanar texture with "size" dependent on the scene units
V-Ray GPU
  • Optimized CUDA CPU performance
  • Optimized interactive scene updates with OptiX
  • Implemented displacement in world space
V-Ray/V-Ray GPU
  • Improved volume intersection & shading
V-Ray GPU/VRayDirt
  • Add support for dirt and curvature attached to extra tex when OOC geometry is enabled
Bug fixes
V-Ray Proxy
  • Fixed export of animated proxy
V-Ray
  • Fixed VFB History loading very slowly when OCIO configuration is used for display
  • Fixed Dark coat over refractive VRayMtl
  • Fixed slow CarPaint2 preview rendering
  • Fixed difference between glossy and mirror caustic reflections from metallic surfaces
  • Fixed VRayCarPaintMtl2 coat IOR <1 not consistent in V-Ray and V-Ray GPU
V-Ray GPU/VRayBlendMtl
  • Fixed fireflies in additive mode with multiple coat layers
V-Ray GPU
  • Fixed GPU Memory leaks after interactive updates when there is CarPaint2 material in the scene
  • Fixed texture on objects with normal displacement appearing smudged in GPU production renders with on-demand mipmapping
  • Fixed crash when using vrmesh file with more than 16 material and UV maps
Build 5.00.45
Official release, Hotfix 3
Date - Apr 28, 2021
Improvements
  • Instances and Multi-instances support
  • Support blending of multiple material assignment tags
  • Motion blur samples override for objects
  • Support Cinema 4D S24
Bug fixes
  • Hair is rendered without motion blur
  • Crash when switching projects with Volume Grid preview in Cinema 4D
  • The MultiMatte render element renders different result in V-Ray GPU compared to V-Ray
  • V-Ray GPU production crashes if there is applied material with missing texture
Build 5.00.44
Official release, Hotfix 2
Date - Mar 25, 2021
Improvements
  • VolumeGrid Preview Rollout for Cinema 4D - Velocity Streamlines
  • Integrate V-Ray TexRamp texture
  • Support for Cloner object with V-Ray Volume Grid in Cinema 4D
Bug fixes
  • Distributed rendering doesn't work correctly when rendering animations
  • Wrong material assignment on objects with dynamic caches
  • HairNextMtl doesn't work with bitmaps assigned to the diffuse color
  • Materials get tiled when scaled even if "tile" setting is disabled in Attributes manager
  • Image sequences are not rendered when used with the Cinema 4D bitmap
  • Cinema 4D noise doesn't work when used in Blend Material
  • Relative file paths do not work for non-texture assets
  • Deformed geometry does not update in animation
  • Motion blur only works for the first rendered frame
  • The Distance texture is not affected by geometry with applied skin deformer
  • Crashes on MacOS systems with more CPU cores
  • Cloning Proxy objects doesn't copy the assigned materials
Build 5.00.43
Official release
Date - Feb 11, 2021
Improvements
  • LegacySceneConverter: Support of converting object layers
  • LegacySceneConverter: Support for more converted types (Materials and Composite Tag)
  • Render Elements: Prevent drag and drop of non-render element objects in the render elements list
  • Exported lights should consider visibility and layers flags
  • VRayVolumeGrid: VolumeGrid Preview Rollout for Cinema 4D - Container and Voxel Preview
  • Ability to convert scenes via script with python (c4dpy)
  • Add an option to disable the automatic conversion pop-up window when opening V-Ray 3.7 scene
Bug fixes
  • V-Ray doesn't respect the "Render" option in the Cinema 4D layers
  • Wrong texture projection of child objects
  • Native C4D noise shader doesn't render correctly when rendering with DR
  • Missing Phong tags may cause different buckets from slaves with DR
  • Wrong UVW coordinates when generated with V-Ray Material
  • VRayProxy: Copying Proxy objects doesn't copy the assigned materials
  • Displacement is wrongly applied when geometry is cloned
  • The "Use mtl ID" parameter in the ObjectSelect RE doesn't work
  • Objects saved in the content browser do not show the materials applied to them
  • Interactive: Starting Interactive with unsupported camera makes the render buttons inactive
  • Interactive: VFB settings and layers are reset when changing material preview scene or creating material
  • Exported animation does not have second frame values in vrscene
  • Applying material to a poly selection should happen only in "Polygon" mode
  • VRayVolumeGrid: When two or more VolumeGrids in Cinema 4D load the same cache, their previews are not updated correctly when scrolling the timeline
  • Improve Interactive and UI responsiveness when tweaking materials and textures
  • V-Ray GPU: Normal displacement has wrong normals
  • V-Ray GPU: Incorrect GPU LPE REs with Light Cache
Build 5.00.42
Official release
Date - Dec 10, 2020
New Features
  • Implement Chaos Cloud Submit dialog and initial integration with Cloud client
  • Add support for VRScans (V-Ray Scanned Material)
  • Implement MultiSubTex shader
Improvements
  • VolumeGrid voxel and bounding box preview for loaded caches
  • Support for Cinema 4D noises with V-Ray GPU
  • Add Object Select Render Element
  • Add MultimatteID Render Element
  • Support for the Cinema 4D "Background" object
  • Implement V-Ray image output options
  • Keep the FOV when Film Gate is changed and Specify FOV is checked
  • V-Ray Light previews should hide when the Viewport filter for lights is off
  • Make the Auto White Balance option a checkbox
  • Set the default Mix Type for some float textures to "Normal"
  • Change the size step for several real parameters to be more intuitive
  • Improve user interface for V-Ray FastSSS2 and Light material
  • Improve user interface for V-Ray Dirt and Distance shaders
  • Improve user interface for V-Ray Sun
  • Menu command for triggering V-Ray 3.7 scene conversion
Bug Fixes
  • Drag and Dropping a material to a polygon selection doesn't create a selection tag
  • Polygon selections are not working correctly with correction deformer attached to objects
  • Polygon selections are not working when the name of the poly select tag is the same as the texture tag name
  • Region rendering with production does not work on the first render
  • Exporting a vrscene with single non-zero frame does not render the same frame
  • Textures loaded with V-Ray bitmap are not saved correctly in the content browser
  • VFB spin controls delimiter does not match the one in Cinema 4D
  • Textures are not mapped in Environment fog and VolumeGrid
Build 5.00.41
Beta Release
Date - Nov 04, 2020
New Features
  • V-Ray VolumeGrid (WIP)
  • About dialog with automatic version update checks
  • Support for Cinema 4D noise shader without baking (CPU only)
Improvements
  • Improvements on V-Ray Proxy export and import including animations and material assignments
  • Support for Filter shader without baking
  • Add multiplication mix mode for distance parameters and shaders
  • Support the basic material override options - without channel overrides
  • Rearrange the GPU engine selection and the rendering devices button
  • Expand the glossiness texture and Mix by default for VRayMtl
  • Add presets for Light Path Expressions
  • Adding the Beauty render elements now automatically sets up composite layers
  • User interface of Bump material
  • User interface of VRayBitmap
Bug Fixes
  • Materials in parent objects do not work with polygon selections in child objects
  • Normal bump maps do not work on V-Ray GPU
  • Velocity render element does not work without enabling motion blur
  • V-Ray does not respect the final image size output units
  • V-Ray has wrong verbose level for the Console log
  • GPU Production rendering does not respect the Noise threshold from the Production settings
  • Canceling the Cinema 4D quit dialog makes V-Ray unusable
  • Broken help page anchors for V-Ray lights
  • VFB layers are preserved on new scenes
  • ZDepth render element has additional gamma applied in Picture Viewer and output
Build 5.00.40
Beta Release
Date - Sep 28, 2020
New features
Installation
  • Integrate the new installer design in V-Ray for Cinema 4D
  • Embed the License Server installation in the V-Ray for Cinema 4D installer
User Interface
  • Overhauled UI for V-Ray Render Settings
  • Overhauled UI for the V-Ray Render Elements manager
  • Overhauled UI for the V-Ray Material
  • Implement V-Ray Lights as separate objects
  • Redesigned icons and menu
  • Integrate V-Ray VFB as a native Cinema 4D window
  • New V-Ray Virtual Frame Buffer with light mix and compositing capabilities
V-Ray
  • V-Ray is now based on V-Ray 5 Core
  • Implemented V-Ray Geometry tag for Displacing and Subdividing geometry
  • Implemented V-Ray Environment Fog as separate object
  • Implemented new V-Ray Proxy
  • Hash map based light cache
  • Adaptive Dome Light
  • Implemented blue-noise optimization for the DMC sampler
  • Implemented "Improved" sky model for V-Ray Sun
  • Added new Coat and Sheen render elements
  • Added new LightMix render element
  • Automatic Exposure Control and White Balance
V-Ray GPU
  • Implement V-Ray GPU as a separate Production rendering engine
  • Added support for RT cores of NVIDIA RTX cards (RTX Engine)
  • Support for Bucket rendering
  • Ability to select devices directly inside Cinema 4D
  • Initial support for Out-of-Core rendering
Materials
  • Added additional Coat and Sheen layers to V-Ray Material
  • Added Metalness parameter to V-Ray Material to support PBR workflows
  • Added V-Ray Hair Next - new physically based hair material
V-Ray Denioser
  • Added Nvidia AI Denoiser
