© Taichi Kobayashi
« Previous Version 4 Next »
This page provides information about the Real Color render channel in V-Ray for Houdini.
The Real Color Render Channel is a color image that shows the original colors that were clamped or adjusted with Color Mapping. This render element is useful in the compositing process for enhancing extreme colors (very bright or very dark) or for shading the final image with the unclamped colors.
When Color Mapping is used, the values that are clamped depend on whether the Clamp Output option has been enabled, as well as the rest of the Color Mapping parameters.
UI Path: ||out Network|| > V-Ray Render Elements node > V-Ray > Render Channel > V-Ray Color Channel (RE) > Type > Real Color
Usage Example
Unclamped Color Render Element
Beauty Composite Render
Composite using Unclamped Color, made warmer
