Square Enix © Goodbye Kansas
« Previous Version 60 Next »
This page describes the new V-Ray Proxy in Maya.
VRayProxy loads geometry from file on disk at render time only. The geometry is not present in the scene, and does not use up any resources, except for the viewport preview. This allows rendering scenes with many millions of faces, more than Maya itself can handle.
The V-Ray Proxy in Maya is a VRayProxy node that loads the geometry from a file on disk. The node loads alembic ( .abc ) and V-Ray Proxy ( .vrmesh ) files. Any mesh can be exported to an .abc  or .vrmesh file from Maya and then loaded as a proxy.
Meshes are exported to a special  .vrmesh  file format. This file contains all geometric information for a mesh such as vertices and face topology as well as texture channels, face material IDs, smoothing groups, and normals. In short, everything that is needed to render the mesh is included in the file. In addition, the mesh is preprocessed and subdivided into chunks for easier access. The file also contains a simplified version of the mesh used for preview purposes in the viewports. More information about the  .vrmesh  file format is available in the V-Ray SDK documentation that comes with the V-Ray for Maya installation.
This page describes working with the new and improved VRayProxy node in V-Ray 5 that's simpler, faster and offers new and powerful features.
Scenes using the old V-Ray Proxy can be easily converted to the new VRayProxy with the built-int converter found in the V-Ray menu > Tools > Convert to New V-Ray Proxy Node.
After loading the file, the V-Ray Proxy attributes are accessible in the Attribute Editor.
To load files with V-Ray Proxy, see the Import V-Ray Proxy page.
To export meshes to V-Ray Proxy, see the Export Mesh to V-Ray Proxy page.
For more information on how to work with the V-Ray Proxy, see the V-Ray Proxy courseware page.
Basic Parameters
File name – The source .vrmesh file. Animated proxies can be stored either in one single file, or as a sequence of files with one file per frame. In the latter case, you can use the string <frame0n> in the file name to have it replaced with the current frame number at render time, where n is an integer number specifying the number of digits. For example, if you enter my_proxy_<frame04>.vrmesh as the file name, this will be expanded to my_proxy_0000.vrmesh for frame 0, my_proxy_0001.vrmesh for frame 1, and so on. If you use a sequence of files, the Playback type option is ignored, as V-Ray doesn't know how many frames are in the animation. The Playback speed parameter may also work unreliably with sequences of files.
Geometry to load – Select the viewport preview mode from the drop down menu. This does not affect the final render. This parameter is Keyable and can be used as a driven key as Geom Type in the Channel Box.
None – No preview. This mode does not read any information from the proxy file and is useful for loading many and massive proxies for final scene assembly.
Bounding box – The mesh is represented as a box scaled to fit the object in viewport.
Preview Geometry – The mesh is represented as a low poly proxy preview as defined in the .vrmesh file. A preview is generated on the fly for .abc files.
Full Geometry – The full geometry of the mesh is visible in the viewport. The new V-Ray Proxy uses an optimized preview based on Maya GPU Cache objects in this mode.
Flip Axis – Switches the proxy's vertical axis between Y and Z. It allows aligning vertical axis of the proxy with the vertical axis in the scene in cases where the proxy was not exported from Maya or when loading Alembic files.
Particle Render Mode – Controls how the particles in the proxy are rendered in the viewports. The available options are Point and Sphere.
Tessellate Hair – When enabled, tessellates hair strands for files containing hair.
Edge length (in px) – Specifies hair edge length in pixels for smoothing hair strands.
Object Hierarchy
The proxy file structure is represented in a tree view with its full hierarchy. You can select individual elements and assign visibility or material overrides. Double click on the hierarchy level labels to expand/collapse the hierarchy.
Viewport Picking – This option is available when Geometry to load is set to Bounding boxes. It allows you to select parts of the proxy directly from the viewport and mark them in the Object Hierarchy.
Filter – A field allowing you to filter the nodes from the hierarchy list. Wildcards can be used in this field. Note that your filter input will not transfer if you copy the tab.
Override Shader – Allows overriding the material for the currently selected node in the tree. You can also enable an override for the selected material via its icon. When an override is enabled, it is indicated by icon.
Material Override – Connect a material to override the currently selected material node. The override can be removed with the bin icon ().
Override Visibility Allows overriding the visibility for the currently selected node in the tree. You can also enable an override for the selected object via its icon. The override can be removed with the bin icon ().
There are 3 states of the visibility override: default (inherit), force visible and force invisible.
Default In this state , the selected object in the hierarchy will inherit the visibility override from its parent(s). The parent objects in the hierarchy may have the same default state, which means that visibility is not overridden.
Force Visible – In this state , the selected object in the hierarchy will always be visible. This can be used to force an object visible, while the parent objects are forced invisible. The state is inherited by the object's children in the hierarchy.
Force InvisibleIn this state , the selected object in the hierarchy will always be invisible. This can be used to force an object invisible, while the parent objects are forced visible. The state is inherited by the object's children in the hierarchy.
Import/Export material rules () button – Right-click the button to select import or export of material override rules to/from the current proxy. The syntax is the same as the Material assignments file, utilizing the new sceneMaterial tag.
The import option reads the file and applies the rules in the Attribute Editor. Importing material assignment rules only adds to the existing ones, overriding only the matching ones. Import can be undone.
The export option writes all material overrides from the tree hierarchy as well as any custom overrides. Exporting the rules does not remove them from the scene.
Old material assignment rules (that don't use the sceneMaterial tag), cannot be imported from this button and only show a warning. Newly exported rules can be imported or used as а Material assignment file together with a .vrscene file with materials.
The new VRayProxy offers rule-based visibility and material overrides. Note that the rule-based (advanced) overrides are executed prior to the hierarchy overrides.
Advanced Overrides
The list of Advanced Overrides is executed from the bottom to the top. Advanced Overrides are executed prior to the hierarchy overrides. This allows adding a more general override with a wildcard, then refining it using the hierarchy.
Visibility Overrides (wildcard)
Add New Item –Adds a new visibility override rule.
Rule – A field to add the name or path of an object from the file's hierarchy. The object matched by the rule will receive the override.
Visible – Specifies whether visibility should be on or off.
Shader Overrides (wildcard)
Add New Item –Adds a new shader override rule.
RuleA field to add the name or path of an object from the file's hierarchy. The object matched by the rule will receive the override.
Shader – Connect a scene material to assign it to the objects matched by the rule.
The rule can be removed with the bin icon () , and the Up/Down buttons () allow re-ordering the list. For more information, see the Applying Advanced Override examples.
Overrides can also be applied to multiple objects in the hierarchy, as long as their names contain the same keyword. For more information, see the Applying Override to multiple objects example.
Example: Applying Visibility Overrides
There is no difference between applying Visibility Overrides to .vrmesh (V-Ray Proxy) files and .abc (Alembic) files. Visibility overrides are applied to objects in the hierarchy.
You can use asterisks as wildcards when inputting the names of the objects/ groups in the Rule. Pressing Enter confirms the input.
  • In the first example: typing /group2/group1/* matches all objects contained inside group1, which is contained inside group2.
  • In the second example: the desired object is selected from the hierarchy and its path is then highlighted and dragged, using the middle mouse button, to the Rule. Pressing Enter confirms the input and applies the Visibility Override to that object.
NOTE: Alternatively, the name can be typed out manually.
Example: Applying Shader Overrides
V-Ray Proxy files (.vrmesh) contain in their hierarchy objects and the materials applied to them. The Shader Override is applied to the material applied to the object(s).
Alembic files (.abc) contain only objects in their hierarchy and the Shader Override is applied to objects, not materials.
Example: Applying Override to objects with similar names
In this example, typing *cube* (the word cube in asterisks) in the Rule targets all objects in the hierarchy containing that word. This applies the Visibility Override to both of them. This input is applicable to both .vrmesh and .abc files.
Animation Parameters
Playback speed – A multiplier for the speed of the animation. Putting negative numbers here makes the animation play backwards. This option may not work very well for sequences of .vrmesh files.
Use alembic animation offset – When enabled, automatically uses the frame offset from the alembic file. When disabled, the frame offset is set manually.
Start offset – Offsets the beginning of the animation by the given number of frames. You can use positive as well as negative values here.
Playback type – Specifies a playback mode. This option is ignored if you use a sequence of separate .vrmesh files.
Loop – The animation is looped by skipping to the first frame once it has finished.
Play once – The animation is played once.
Ping-pong – The animation is looped by playing it backwards once the last frame has been reached and then playing it forward again when the first frame is reached.
Still – The animation is not played. Instead, just the Start offset frame is shown.
Sequence override – Allows you to manually override the start frame and the animation length to read (in frames) for animations stored in sequences of .vrmesh files (where each frame of the animation is stored in a separate proxy file). Importing proxy sequences requires a special format that specifies how to match the frame padding in the file name. See the  File name section of the Import V-Ray Proxy page for more details.
Sequence start – Specifies the first frame of the animation.
Sequence length – Specifies the length of the animation to be played.
Alembic Layers
The Alembic layers feature allows modification of a selected alembic proxy by adding layer files on top of it. Each layer transforms the proxy with a different set of properties. These transformations include adding properties to a shape (e.g. UV mapping of an object that has no UVs), overriding properties, adding new objects, pruning objects or properties, replacing an object's (or properties') hierarchy with a new one, etc.
You can combine different cache files. Whenever the same object is found in a layer, all of its properties are considered.
Add New Item – Adds a new layer to the stack.
Enabled – Each layer's effect can be enabled or disabled by the checkbox.
File – Loads an .abc file that can be used as a supplement or an override on top of other alembics. For example, you can add an alembic file that contains UVs to another alembic containing a polymesh without UVs.
Browse – Allows you to browse and open an .abc file.
Delete – Removes the layer from the stack.
Alembic proxy parameters
Starting object path – Allows to specify a starting path in the Alembic file; only objects below that path are rendered. The path may start with ABC/ or it may be omitted.
Recompute bounding box – Enabling this check box forces V-Ray to recompute the bounding box for the geometry before rendering. When this is off, V-Ray uses the bounding box specified in the Alembic file. However, sometimes these bounding boxes are not correct, and in that case the rendering is also incorrect. To avoid such issues, enable this option. Note that this option might slow down the rendering.
Instancing – When enabled, if there are multiple instances of an object it is loaded once and the memory is reused.
Compute normals – This option allows you to force smooth normals on the geometry in case they were not originally smoothed.
Smooth angle – When the Compute normals option is enabled, this specifies the angle below which normals are smoothed.
Flip normals – Reverses the direction of the normals.
Preview faces – Allows you to specify how many faces are going to be used to show a preview of the proxy in the view port.
Preview hairs – Allows you to specify how many splines are going to be used to show a preview of the proxy hair in the view port.
Hair width multiplier – This multiplier allows you to control the hair width during rendering.
Preview particles – Allows you to specify how many particles to show in the viewports.
Particle width multiplier – Controls the size of the particles when rendering.
Velocity multiplier – Controls the length of the motion blur when rendering.
Subdivide all meshes – Subdivide the meshes before rendering using the OpenSubdiv library.
Subdivision level – The number of subdivision levels.
Subdivide UVs – Allows you to choose whether or not the UVs of the object are subdivided at the borders.
Preserve geometry borders – Specifies whether geometry borders are preserved or not.
Preserve map borders – Specifies how to handle subdivisions of UV coordinates at UV seams when Subdivide UVs is enabled. The possible values are:
None – UVs are always subdivided regardless of whether they are on a UV seam or not.
Internal – Only preserve UVs if they are on an internal UV seam.
All – Does not subdivide UVs on UV seams.
Point Cloud
Use if present – Enables the usage of point cloud data if available.
Level multiplier – Determines the way point cloud levels are loaded. A value of 1.0 means that the level to load is determined exactly by the distance from the camera to the object. A value smaller than 1.0 means that the level is of greater detail than required by distance. Values greater than 1.0 mean that the resolution of the level is smaller than the one determined by distance. A value of 0.0 means that no point cloud level is loaded and the original mesh is rendered instead.
VRayMesh file info
This rollout provides information on the loaded VRayMesh including:
  • Mesh filename, i.e. a path to the loaded file
  • Animation contained in the proxy (when animation is in one file, not as a sequence of files)
  • Number of voxels
  • Number of preview faces, hair geometries and particle count.
  • Bounding box information
  • UV sets and their names
  • Color sets and their names
  • Shaders sets and their full names
This can be useful in several situations. For example, when using the VRayUserColor node to read UV sets and color sets, the set names can be found in this rollout. Additionally, when using animation overrides, the rollout shows what frame of the proxy animation is rendered at a given timeline frame.
Material Assignment Overrides
When loading a proxy file in a VRayProxy node, materials stored in . vrscene files can be assigned onto different objects from the proxy file. This requires a pair of a .vrscene file containing the materials and an XML file containing the "rules" for applying them to the objects in the proxy filе.
Material assignments fileSpecifies the location of an . xml file that contains the "rules" for material assignment. For alembic files, the "rules" are based on object paths, for .vrmesh files, they are based on material names. The wildcards * are allowed in the .xml file.
Alembic Sample XML script
<materialAssignmentRules>
	<patternRule>
		<pattern>/pCube*</pattern>
		<material>VRayMtl1@material</material>
	</patternRule>
</materialAssignmentRules>
The sample XML assigns the  VRayMtl  material to all alembic objects matching the pattern  pCube* , i.e. all objects whose name starts with  pCube .
The new alembic proxies are imported with full path names by default, so the pattern <pattern>pCube*</pattern> won't work for them, but <pattern>/pCube*</pattern> will.
If you want to use the new proxy with your old XML file unchanged, import the alembic files with the Use full path names option disabled (this can be done via scripting but then you'll loose the Object Hierarchy), or try using the Convert To New V-Ray Proxy Node tool (it keeps the old short path names as well as the linked rules file, but again you loose the Object Hierarchy). Otherwise, the material assignment override rules will need to be adjusted to match the full path names pattern.
Proxy Sample XML Script
	<patternRule>
		<pattern>VRayMtl1</pattern>
	</patternRule>
The sample XML assigns the  VRayMtl1  material to all vrmesh objects matching VRayMtl1 pattern, i.e. all objects whose material name is VRayMtl1.
Post-translate Python script
from vray.utils import *
appendSceneContent("C:/mtlAssignments/materials.vrscene")
For this feature to work, you need to specify the path to the . vrscene  containing the materials (procedural textures or paths to bitmaps). This only works with post-translate python script. The following example script specifies the path to the . vrscene  file and should be copied  into Render Settings > Common > MEL / Python callbacks > Post translate python script.
Alembic Sample XML script with sceneMaterial tag
	<patternRule>
		<sceneMaterial>VRayMtl1@material</sceneMaterial>
	</patternRule>
The sample XML assigns the VRayMtl material to all alembic objects matching the pattern  pCube* , i.e. all objects whose name starts with pCube. It uses the new sceneMaterial tag.
The material assignment overrides is still an experimental feature and can change at any point!
Example: Instancing V-Ray proxy with MASH
This example shows how to instance a proxy (.vrmesh) using MASH.
Load a proxy file into your scene using the Import V-Ray Proxy button in the toolbar.
To instance the proxy, while still selected, create a MASH Network (MASH > Create MASH Network). As a Geometry Type, select Instancer.
Now you can adjust the distribution.
The same steps apply when using an alembic file.
  • V-Ray 5.0 for Maya 2018 and above supports instancing of .vrmesh files via the Maya Instancers found in FX menu set > nParticles > Instancer.
  • To create a Maya Mesh from the geometry from file (including normals, default uv set and per face shaders), you can use the -vrayImportVRmeshGeom command. Available flags are -frame (specifies which frame from an animation to consider), -loadHair (imports hair data) and -name (sepcifies a name for the newly created node).
    Example: Animation Frame
    vrayImportVRmeshGeom "D:/anim_foliage.abc" -frame 13 -name "Foliage"
    Example: Import Hair Data
    vrayImportVRmeshGeom "D:/hair.abc" -loadHair -name "Hair"
