« Previous Version 15 Next »
This page provides information about V-Ray supported version of platforms that can make use of Chaos Cloud.
Each Chaos Cloud job is rendered with the latest publicly available build of the V-Ray version used to create the original scene, e.g. a scene created with V-Ray Next is rendered with the latest publicly available version of V-Ray Next.
Important about scenes created with V-Ray 3: All failed jobs created with V-Ray 3 will still be automatically refunded. However, issues with such jobs won't be investigated by the Chaos Support teams as V-Ray 3 is officially not supported anymore.
V-Ray 5
WindowsLinuxmacOS
3ds Max® 2016 and later--
Maya 2017 and laterMaya 2017 and laterMaya 2017 and later
SketchUp 2017 and later-SketchUp 2017 and later
Rhino v6.29.20238 and later
Rhino v7.0.20314 and later
Cinema 4D R20 and later-Cinema 4D R20 and later
Revit 2018 and later-
V-Ray Next
WindowsLinuxmacOS
3ds Max® 2013 - 2021--
Maya 2015 - 2021Maya 2015 - 2021Maya 2016.5 - 2021
Houdini 18.5.499 and laterHoudini 18.5.499 and laterHoudini 18.5.499 and later
Rhino 5.14 and later (64-bit versions only);
Rhino 6.13.19058 and later
SketchUp 2016 (64-bit) - 2020-SketchUp 2016 (64-bit) - 2020
Revit 2015 - 2019--
Modo 901 and later-Modo 901 - Modo 13
V-Ray 3.6
WindowsmacOS
Cinema 4D R18 and later *Cinema 4D R18 and later *
Modo 701 (SP5), 801 (SP2 or higher) and laterModo 701 (SP5), 801 (SP2 or higher) and later
Rhino 6.6.18117 and later
SketchUp 2015 and laterSketchUp 2015 and later
Revit 2015 and later-
*Only still images are supported in Chaos Cloud with V-Ray 3.7 for Cinema 4D.
