« Previous Version 17 Next »
This page provides information about V-Ray supported version of platforms that can make use of Chaos Cloud rendering.
Each Chaos Cloud job is rendered with the latest publicly available build of the V-Ray version used to create the original scene, e.g. a scene created with V-Ray Next is rendered with the latest publicly available version of V-Ray Next.
Chaos Support team provides support for the following products:
- V-Ray 6 for: 3ds Max, Maya, SketchUp, Rhino, and Cinema 4D
 - V-Ray 5 for: 3ds Max, Maya, Houdini, SketchUp, Rhino, Revit, and Cinema 4D
- V-Ray Next for: Revit, Houdini, and Modo
All failed jobs created with earlier V-Ray versions will still be automatically refunded. However, issues with such jobs won't be investigated by the Chaos Support teams.
Cloud Rendering Compatibility
Product VersionsV-Ray 6V-Ray 5V-Ray NextV-Ray 3.6
WindowsLinuxmacOSWindowsLinuxmacOSWindowsLinuxmacOSWindowsLinuxmacOS
3ds Max®
2018 or later
--2016 & later--2013 - 2021--
Maya2019 & later2019 & later2019 & later2017 & later2017 & later2017 & later2015 - 20212015 - 20212016.5 - 2021---
Cinema 4DR20 &later-R20 & laterR20 & later-R20 & later
--R18 & later*-R18 & later*
Houdini---18.5, 19.0, 19.518.5, 19.0, 19.518.5, 19.0, 19.518.5.499 & later18.5.499 & later18.5.499 & later---
Revit---2018 & later--2015 - 2019--2015 & later--
Rhino
v6.29.20238 & later
v7.0.20314 & later
v6.29.20238 & later
 v7.0.20314 & later
5.14 & later (64-bit only)
6.13.19058 & later
--5.14 & later (64-bit only)
6.6.18117 & later
SketchUp2019 - 2022-2019 - 20222017 & later-2017 & later2016 (64-bit) - 2020-2016 (64-bit) - 20202015 and later-2015 & later
Modo------901 & later-901-13
Modo 701 (SP5)
801 (SP2 or higher) & later
Modo 701 (SP5)
*Only still images are supported in Chaos Cloud rendering with V-Ray 3.7 for Cinema 4D.
Chaos Support
ProductV-Ray 6V-Ray 5V-Ray Next
3ds Max®(tick)(tick)(error)
Maya(tick)(tick)(error)
Cinema 4D(tick)(tick)(error)
Houdini(error)(tick)(tick)
Revit(error)(tick)(tick)
Rhino(tick)(tick)(error)
SketchUp(tick)(tick)(error)
Modo(error)(error)(tick)
