« Previous Version 10 Next »
Introducing Chaos Player
Fast-forward your digital review workflow with Chaos Player, a professional image sequence player designed for fast and smooth playback.
Review your own or your team’s animation output in playback right after the rendering finishes. See new and updated frames instantly. Chaos Player is also powered up for basic compositing, color grading, and editing in real-time —  even while playback is running. And much more.
Features
Contact Sheet
Organize different versions of the same shot, or different image layers (render elements) into a sheet for comparison and evaluation.
Playback image sequences
Playback high-resolution image sequences quickly and efficiently with Chaos Player’s smart caching system. New and updated frames load instantly.
Layer sequences
Layer multiple sequences for simultaneous playback. By stacking layers, you can composite, edit and cut, tech check, and more.
A/B Wipe Compare
Compare up to four versions of a shot in playback. Swipe and zoom into the details to tech-check and perfect your own and other people’s work.
Export to MP4
Export your cuts, edits, and compositions to MP4 videos or choose from a variety of image formats.
Composite
Composite layers quickly and easily in real-time while playback is running. Export to Adobe After Effects or Foundry’s Nuke for final output.
Adjust colors
Quickly and easily fine-tune exposure, contrast, color balance, and layer blending modes in real-time while playback is running.
Edit and cut
Quickly arrange your shots, cut sequences, or add animated fade effects.
Broadcast and collaborate
Share previews of your animations on a HTTP server or directly on a broadcast monitor. Share ideas with your team by adding text and brush annotations.
Key and grade on set
Key, composite, and grade live on set and in real time.
Command line support
Seamlessly integrate Chaos Player into your pipeline with extensive command-line support.
