Important: Update Your Chaos Licensing by January 28, 2025
To ensure uninterrupted access to your licenses, an essential update is required by January 28, 2025. Failure to update your Chaos licensing will result in the loss of access to your licenses. For detailed instructions, please visit the FAQ Article.
Introducing Chaos Player
Fast-forward your digital review workflow with Chaos Player, a professional image sequence player designed for fast and smooth playback.
Review your own or your team’s animation output in playback right after the rendering finishes. See new and updated frames instantly. Chaos Player is also powered up for basic compositing, color grading, and editing in real-time —  even while playback is running. And much more.
Features
Contact Sheet
Organize different versions of the same shot, or different image layers (render elements) into a sheet for comparison and evaluation.
For more information, click here.
Playback image sequences
Playback high-resolution image sequences quickly and efficiently with Chaos Player’s smart caching system. New and updated frames load instantly.
For more information , click here.
Layer sequences
Layer multiple sequences for simultaneous playback. By stacking layers, you can composite, edit and cut, tech check, and more.
A/B Wipe Compare
Compare up to four versions of a shot in playback. Swipe and zoom into the details to tech-check and perfect your own and other people’s work.
Export to MP4
Export your cuts, edits, and compositions to MP4 videos or choose from a variety of image formats.
Composite
Composite layers quickly and easily in real-time while playback is running. Export to Adobe After Effects or Foundry’s Nuke for final output.
Adjust colors
Quickly and easily fine-tune exposure, contrast, color balance, and layer blending modes in real-time while playback is running.
Edit and cut
Quickly arrange your shots, cut sequences, or add animated fade effects.
Broadcast and collaborate
Share previews of your animations on a HTTP server or directly on a broadcast monitor. Share ideas with your team by adding text and brush annotations.
Key and grade on set
Key, composite, and grade live on set and in real time.
Command line support
Seamlessly integrate Chaos Player into your pipeline with extensive command-line support.
